I cannot enable bluetooth capability on my Chromebook. I can see the option to enable it in the submenu and in the settings but it still won't turn on. It has worked for me in the past with no problem. I have already rebooted twice. No go.
SOURCE: I've been using my chromebook for a year now with
Have you tried "forgetting" the wireless network settings on your account and then reconnecting?
SOURCE: my acer chromebook AC710 SCREEN IS CRAZY CANT SEE ANYTHING BUT COLORS AN LINES WHAT TO DO?
throw any acer chromebook in the garbage or give it to a preschooler to learn to do absolutely nothing with. its the biggest waist of money ive ever spent in my life.
SOURCE: My Acer Chromebook 13 will not power on or charge so can anyone help me with my problem?
try this: remove battery, remove power cable, push and hold down the power button for 1 m (over 60s) do not short time. release the button, insert the power cable. wait 10s then push and hold power button till you see any lite flash release and see if you boot.
some time the static is built and that causes failure to start.
above should clean any static and allow reset of power adapter to function. if yes,. then once you shut down . insert the batter and ;et it charge for 3 mins.. then try to start.
