GE WDSR2080D Top Load Washer Logo
A
Anonymous Posted on Jul 28, 2014
Ge washer all lights are on and it doesnt respond
All lights are on try to push on any button and doesn't work
Jerry Mullins
Level 1:
New Friend:
Night Owl:
An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • Contributor 50 Answers
  • Posted on Jul 28, 2014
Jerry Mullins
Contributor
Level 1:
New Friend:
Night Owl:
Answers
50
Questions
6
Helped
13842
Points
74
Unplug the power cord to reset the control board, If that doesn't work the board is probably bad. It will have to be checked with a multimeter.
Why won't my washer start when I push the start button
My washer use to not work and I took off the rubber cover that covered the button and was then able to just push the stem inside to start the machine. It worked fine afterwards.
The probe doesn't work on my JT912 GE wall oven
Test Continunity for your Probe, if it has good continuity, then you have a internal issue with the Oven... More than likely, you are going to need a Technician
HE3 doesn't respond to any button. Time light keeps flashing time. Pause cancel button does nothing, Cycle doesn't start. The only thing that will change is if you push a different mode ie, heavy,...
Unplug the machine for at least half an hour to eliminate the possibility of an electronic glitch. Then upon plugging in back, close the door then push CONTROL/ON (if present on this model). Select the DRAIN/SPIN cycle then select NO SPIN by pressing the SPIN SPEED button. Push PREWASH OPTION four times within five seconds. If PREWASH OPTION is not present on this model, press EXTRA RINSE four times within five seconds. C:00 will light up on the display. If the Starting procedure fails, push the PAUSE/CANCEL button then repeat the starting procedure.
In order to advance to the next step of the test procedure, push PREWASH OPTION button two times. If PREWASH OPTION is not present on this model, press EXTRA RINSE two times. The test program goes from C:00 to C:08 and should flash an error code when a problem is present. Post the code back for further troubleshooting, including the exact model number of the machine.
1helpful
2answers
My Sony vaio pcg 3c2l has locked up. The keyboard stopped responding and now the screen is black, but the power light is still on. The power button doesn't respond when I push it. What should I do?
Try pressing the power button for several seconds (10-15). It should power off the laptop.
If not, unplug the charger and remove the battery for a few minutes. Then try to start it up again.
5helpful
The machine's "Control Locked" light is on.
Did you try to push and hold the 'CYCLE END SIGNAL' button for 3 seconds?
GE JTP70 convection oven - defaults to self-cleaning mode
I believe your control board is going bad. This isn't that expensive. However, get one from a GE parts store. They tend to be better priced.
5helpful
CONTROL LOCK and Can't start the GE front load washer - WSSH300GWW
Try buttons "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for over 5 seconds.
Or press "options & select" till the light goes off.
Works for other machines..............And please rate me if helped
Top GE Washing Machines Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Virgil Watts
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
