RIM Blackberry Playbook with 64GB Internal Memory Dualcore 1GHz Processor Tablet Logo
A
Anonymous Posted on Jul 27, 2014
Blackberry wont type - RIM Blackberry Playbook with 64GB Internal Memory Dualcore 1GHz Processor Tablet
Bob Sloan
Level 3:
  • RIM Master 2,013 Answers
  • Posted on Jul 28, 2014
Bob Sloan
RIM Master
Level 3:
Answers
2013
Questions
Helped
356862
Points
8519
1helpful
2answers
The key pad wont work wen i type any thing on the screen everything is frozen i have tried removing the battery i cant access anything when i type but it still wont work my key pad i permanently lock for...
Try to insert any password in your phone 10 times to erase all your data and make your blackberry Tour 9630 unlocked. If your keypad still won't work after blackberry unlocking process, try to reflash your blackberry phone. Once again if still have same result, it should be a hardware problem in your phone and you need to repair that on nearest local mobile phone repair shop.
My iphone won't connect to my blackberry, or my handsfree, to allow me to transfer my address book... any thoughts?!
Hi
iPhone will only connect to another iPhone/iPad etc it wont connect with a blackberry to transfer anything you need to try get your content to your computer and sync your details to your iphone via itunes, what type of handsfree do you have? If its not compatible with the iphone it wont connect.
3helpful
4answers
My blackberry ask enter"blackberry" to continue.
It depends for what.
1. If you want to "wipe" ypur BlackBerry and erase all is content, you have to type it to wipe it.
2. If It's for your security password, you have to be careful that's it's not your last attempt. Because if It's so, your blackberry will wipe and you will loose all you information and you will have to reactivated again.
Regards,
BES Tech
2helpful
3answers
Blackberry 8320 unlocking code
It's a clear and fully detailed guide on how to unlock any BlackBerry :
1. Insert any sim card
2. Turn off all of the wireless connections
3. Go to Options
4. Select Advanced Options
5. Select SIM Card
6. Hit menu select show keyboard (if your BlackBerry have touchscreen)
7. Type MEPD ( you will not be able to see what you are typing )
8. Type MEP2 or MEP4 ( you will not be able to see what you are typing )
9. Now the phone will prompt you to enter the mep code
10. if you not already have the code, then i suggest BlackBerryMEP.COM to get it from .
11. Enter the mep code ( you should see "code accepted" )
12. Restart your BlackBerry .
All done.
SOURCE :
BLACKBERRYMEP.COM
2answers
I have blackberry 8700g and i had airtel as my preferred network but now when i am trying to change it to Vodafone, the handset days invalid sim card. Kindly help
You have to get the phone unlocked in order to use it with a different carrier, otherwise it wont work with another sim card. You can buy an unlock code on ebay for about $4.99
www.usedcellphoneshop.com
Blackberry curve wont access password, just types letters and numbers now
What do you mean? Did you forgeting your blackberry password? If yes, you can unlock blackberry curve password with your puk code, just type any password until your phone asking you to enter puk code. PUK code can you found from your sim card bundle if you don't have it just call your service provider, they will give it to you. After you put that puk code your blackberry unlocked from old password.
Dec 13, 2009 • Cell Phones
Typing in blackberry messenger cant do more than 1 word
i have a blackberry curve. my friend tried to tye my password in and got it wrong 10 times. my screen sais 'jvm error 513' and it wont do anything when i click reset. i need help D:
1helpful
3answers
Blackberry pearl wont except sim card
How To Enter the Unlock Codes on a BlackBerry Cell Phone
Model : All BlackBerry Models (except T-mobile)
1 - Using the menu go to Settings Menu -> SIM card press select.
2 - While holding the SHIFT key, type MEPD or (MEPPD for Vodafone Handsets)
3 - You should now see the five locking categories listed.
4 - While holding the SHIFT KEY, type MEP2 or (MEPP2 for Vodafone handsets)
5 - Release the shift key.
6 - You are now prompted to enter the Network MEP code (it will also state how many attempts left)
7 - Enter the code
8 - Enter Return/Enter
9 - The device should then be unlocked
Model : T-mobile BlackBerry Models
1 - On the Home screen, click the Tools icon. The Options screen appears.
2 - In the tools screen, select the Settings icon.
3 - Scroll to SIM Card and select it. You should see the phone number and the SIM ID number.
4 - Type ‘mepd’ to display the first five levels of SIM locking.
T-Mobile uses network locking so the Network should display Active. All other states should display Disabled
Please note: For the Blackberry 7100t you will hit the “P” twice when entering the ‘mepd’ and ‘mep2′ for steps 4 & 5.
5 - Type ‘mep2′ to display the dialog box asking for the unlock code (Press the Alt + 2 key to get the number 2)
6 - Input the Network Unlock code
7 - Press ENTER and reboot handheld.
Model : BlackBerry Pearl 8100 (Alternative instructions if above instructions do not work)
Can be done without a sim card inserted
To Unlock:
1 - While on the home screen, click the “blackberry key” on keyboard, then select “options”.
2 - Choose “Advanced Options”.
3 - Select “Sim Card”
4 - There is no area to type these letters, you just type them as instructed. No need to hit keys twice to get a letter either. Type m e p p d to display the first five levels of SIM locking. Most companies use network locking so the Network should display Active. All other states should display Disabled ( you will not see text appear on screen
while typing )
5 - Type m e p p 2 to display the dialog box asking for the unlock code
(Press the Alt + 2 key to get the number 2) ( you will not see text
appear on screen while typing )
6 - Input the SIM Unlock code
7 - Press in the trackball in once
Your phone is unlocked
3answers
Blackberry curve from sprint
I am going to guess that since you can copy some types of media files to your phone then the problem is the format of the video files you want to copy. The phone's media playing application may not show files it cannot recognize.(or show an error message).
If you want to watch videos (or movies) on any type of smart phone or mobile player then I suggest you download a free application called Format Factory. It converts any type of media file to any other type of media file (video, music, pictures, DVDs). It has settings for Blackberry phones, iPods, PsP, etc. Go to: http://www.formatoz.com/ and check it out.
Phone wont power on
i have a change my password and many time i type wrong password then my handset not work
its show jvm error 513
Top RIM Computers & Internet Experts
ZJ Limited
ZJ Limited
ExpressFiX
ExpressFiX
Alexander
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
