Toro Lawnmower 20099 Mower Mowers Lawn Logo
A
Anonymous Posted on Jul 27, 2014
Why my blade wont engage on my toro 74370 zeroturn mower
The bladesengage
Donny Reynolds
Level 1:
New Friend:
Problem Solver:
  • Contributor 17 Answers
  • Posted on Jul 28, 2014
Donny Reynolds
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
17
Questions
Helped
7914
Points
31
It has an electromagnetic clutch switch on it,that is more than likely bad. Try this,pull the pto switch out and start the engine,then disconnect the 2 wires coming from the switch and just tap them together and see if they will come on. If they do then you need to replace that switch.
I have a toro zeroturn mower motor starts up fine I can drive it around fine, but as soon as I engage the mower deck the motor will start running rough then stall out. why?
Could be there is an obstruction in the deck that is not allowing the blades to turn freely and stalling out the motor.
Sep 13, 2017 • Toro Garden
2answers
Troubleshooting a zeroturn toro lawnmower
generally it's the hydraulic pump that controls that side. it may be going bad
Jul 17, 2012 • Toro Garden
Toro 52 inch walk behind blades won't engage
if it has a electric clutch check for power to the clutch if no check the safety switches
Dixon zeroturn DM 42 Pto will not engage.
did it burn out the clutch?or did you knock off the wires when removing the twine
Apr 07, 2012 • Garden
1helpful
Need manual to see what size bolt is that holds on
Hi and welcome to FixYa. I am Kelly,
It appears your model number is 74370 There are 3 bolts one for each blade and the part number is 26-0671 or 260671 for the blade mount.
Part look up:
http://www.jackssmallengines.com
then enter part number 260671 $6.31 ea.
You can not use just any bolt for this. They are hardened bolts with an NF thread. If you use a non hardened bolt the blade will fly off when the bolt shears.
This bolt is available at most all Lawn Mower Parts Supply sources. Toro uses the same bolt on most all of their mowers.
If you do not have a Lawnmower Parts Supply near by, you might be able to go to an Autoparts supply source with yet one of the other blade bolts in hand and have them match the markings on the bolt head with yours so that you have the exact replacement bolt.
Any other parts for your mower can be found here:
http://www.jackssmallengines.com/help.cfm
Use the Search model window. each line below is a drop down window
Toro
Riding
74370 <- there are numerous models up to 74704
enter your model number if different.
Thanks for using FixYa.
Kelly
Blade not engaging
The blade will spin automatically when the motor runs because it is connected to the main shaft. If it is not cutting, it will have to be removed and sharpened with a grinding wheel
White smoke and blade won't engage
Sounds like a low compression problem. The piston rings have most likely failed and oil is seeping past them and burning, thus the white smoke. An engine needs three things to run...Spark, Compression, and Fuel. Just take the mower back as it is still probably under warranty. Mike. Rate 100% please.
Top Toro Garden Experts
john h
Sean Wright
Sean Wright
Jay Finke
Jay Finke
Are you a Toro Garden Expert? Answer questions, earn points and help others
