Pw was empty of gas, added new gas to use and gas is leaking out from side filter how do i fix
Your washer was sitting for a while I suspect. Check the carb and make sure it is tight to the engine. If it is then you will need to take the carb off, careful not to tear any gaskets. Then remove the fuel bowl and clean out all ports. Make sure to clean out the jet as well as I suspect the fuel is clogged in the carb and overfilling. Your needle valve is stuck open and then flooding your carb and spilling out the side of your engine. Make sure your needle valve and float can move freely before reassembling. Good luck
