Kyocera Km-3060 Mfp Copier Copy Machine Scan Email All-In-One Laser Printer Logo
Anonymous Posted on Jul 27, 2014
How kyocera works
How the machine senses toner bin and quantity of toner powder.i refilled the cartridge but machine says developer unit not installed.
donovin mclain
Level 2:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Kyocera Expert 210 Answers
  • Posted on Aug 06, 2014
donovin mclain
Kyocera Expert
Level 2:
New Friend:
Cheetah:
Answers
210
Questions
Helped
108147
Points
231
Developer and toner are two drifernt things you have to check to see if the developing unit is installed correctly
Testimonial: "kyocera uses peigo sensor. it senses from bottom of the containor."
5 Related Answers
Anonymous
  • 622 Answers
  • Posted on Dec 24, 2009
SOURCE: Kyocera FS-3900 and FS-4000 Prints very faint. New printers affected
sounds good
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Anonymous
  • 62 Answers
  • Posted on Feb 01, 2010
SOURCE: Kyocera laser printer toner refill
refill...uh oh probably wouldnt try it..there's is like only 1 company that does kyocera refill toners.....call KATUN... you can try to find that on the internet..you most likely willl have to buy actuall kyocera toner..
Anonymous
  • 823 Answers
  • Posted on Apr 02, 2011
SOURCE: My Kyocera FS-1030D (duplex) has
You have not wasted your money on the new toner purchase. With a little maintenance, it can last a lifetime.
The "spidery deposits of toner" you are talking about could be caused by a dirty charger wire under the process unit. You mentioned that you just changed the toner cartridge, right? Did you remove the process unit and clean the charger wire under it after you changed the toner? The charger wire has to be cleaned with charger cleaner every time the toner container is replaced.
Do you have the manual which came with your printer? If so, then go to page 39 to find information on printer cleaning tasks. If you have not cleaned the charger wire, dust out the printer with a lint free dry cloth and change it when it looks soiled. Continue dusting and wiping until there is no dust on the cloth. Then remove the process unit (picture on page 39) and wipe out the area with a new lint free cloth until no dust is apparent on it.
Slide the green charger wire cleaner back and forth across the wire as instructed on page 43 of your manual. Reinsert the process unit.
The only other thing that can cause the problem with toner marks is if the registration roller is soiled with toner. Refer to page 18 for instructions on checking and fixing it.
If you dont have a manual, here is a link to get one for free:
http://www.kyoceramita.eu/dlc/eu/documentation/usermanual/fs-1030d-og-uk_pdf.-downloadcenteritem-Single-File.downloadcenteritem.tmp/FS-1030D-OG-UK.pdf
pkwc
  • 254 Answers
  • Posted on Sep 27, 2011
SOURCE: Kyocera FS3900 is printing out
Go to the maintenance menu and do a drum refresh.
else try to clean the transfer roll
Anonymous
  • Posted on Mar 07, 2013
SOURCE: my kyocera fs-1370dn suddenly says it is missing a developer unit when the developer unit is there and was just working
Check that the toner you are using is genuine Kyocera, also that the toner hasn't run out, this is normally a toner related issue.
Hello. My printer Kyocera 2100DN adding toner problem. After 10 minutes, then a message replace the toner.
This happens when the machine knows that you are using counterfeit or refilled toner cartridges. Or your toner refiller gave you an empty one, or one with a teaspoon of toner powder in it.
My kyocera DC 6240 photocopier is showing me refill or replace toner kit even after i have refill it keeps on showing me same thing
you must use OEM toner if you use aftermarket toner that says for use in you will get this problem if you have been using aftermarket toner you will have to change developer or empty all toner from developer unit and start with OEM toner Kyocera stamps their logo into cartridge
I changed the toner in a Kyocera M 3550 and now it prints only a black sheet of paper.
It sounds like the corona wire in the drum unit has broken or the drum is overloading toner. It is also possible that light is getting into the printer an exposing the whole drum to light.
Last and least likely is the toner powder could be the wrong type for your machine. This may have happened if your cartridge is a compatible or has been refilled, and may also happen to an original if it is very old ie more than two years since manufacture.
?I have kyocera 1620 copier, after refilling the toner it start producing black marks on my documents,how can I stop it
You can't stop it. It sounds like you used the wrong toner and now its mixed with the developer powered causing excess toner. check the developer unit. When you REFILL toner you need to make sure it the right toner. toner has different melt points and components. If you use the wrong toner it will mess up the developer and cost much more than to buy a toner cartridge. If you live in Southeast Florida Advanced business computers is a great source for help. Computer network repair, printer copier maintenance repairs, copier printer leasing and supplies.
My kyocera fs-1370dn suddenly says it is missing a developer unit
The developing unit is where the toner sits upon.Remove the toner cartridge and ensure that the developer unit is correctly inserted.Then re-instal the toner cartridge.
How kyocera laser mfpsenses toner bin and powder
toner and developer are different the developer is usaly by the drum check too see if its in the machine or installed correctly
2helpful
2answers
My kyocera fs-1370dn suddenly says it is missing a developer unit when the developer unit is there and was just working
Pls tell me the life time of the developer powder and do I have to use only original toner
Hi, I have not come across any expiry date of toner/ developer and if it is stored properly in a cool dry place, away from sunlight an excessive heat, it works just fine. Re-filling the toner is always cheaper and costs around 1/4th of the new toner price. So, check for the price of new toner and compare. Genuine toner is always better in terms quality and yield. However, refill can work too.
I have refilled/ refurbished toners myself and had no issues. Properly re-filled/ refurbished cartridge would NOT cause any damage to the printer. So, you may get your toner refilled by some good professional and it would work fine. As for Panasonic Workio DP-4530 and similar copiers, the toner comes in a bottle (which is only a container filled with toner powder) and the toner powder is pulled by the toner supply unit of the copier. I am using HP 9065MFP and refilling caused no issues. I usually refill it after proper servicing and use best available powder and it works absolutely fine.
Hope it helps! Good Luck! Thanks for using Fixya! CreativeTECH
1helpful
My machine model is SHARP AR 5520,the problem is that the machine is returning all the toner into the waste bin,all the toner will be sent into waste within an hour or two.this happened when i refilled the...
hello,
problem is your toner cartridge. inside of the toner cartridge have a toner roller it's didn't circling.or you are using duplicate toner powder.it's doesn't match with sharp ar 5520 developer. or your developer was expired.
first use original toner and try to make copies .i think your problem is solved.
2helpful
2answers
Kyocera FS-3900DN Ecosys Call Service 2200:0100998 Help please our printer has stopped working
The Call Service 2200 is a drum motor error. The motor or gears might need to be replaced. First remove and re-seat both the developer and the drum unit. The developer is directly under the toner cartridge - lift it up then out first, then open left side door remove the waste bin and press the button on the drum unit just above the waste bin pull the unit out (carefull not to touch the drum surface). Re-seat both units. If this does not work call in a Kyocera Tech.
Top Kyocera Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Ngoro
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
