SOURCE: yamaha ar 230 engine middle lightcome on in on both tach and shut
With the newer yamaha jet boats your route of easiest resistance is gonna be to take the boat to a Yam dealer so they can put a diagnostic machine on it. Alot of sensor problems can be solved much easier and cheaper after running the diagnostic and pinpointing exactly what the issue is. The lights on the dash are for high temp and low oil. If you checked the water temp and it seemed ok, check your oil levels.
SOURCE: the toilet recycles every ten minutes
You got a bad seal for sure. Even though it looks like a good seal. Open up the lid and see if you got any little bubbles floating up from around the seal or listen for a slow water drain around the seal. Go to Lowes and tell them you need a Korky flapper. Their the best thing since sliced bread and peanut butter.
SOURCE: My washing machine stops at 26 minutes and water
how much water? Is it coming out when the machine is in the drain cycle? The drain pumps on these machines are known to get holes in them.
SOURCE: Fisher & Paykel Frigidaire Excellence
May be one of the fill valves are not opening when it is calling for either cold or hot water. Have the solenoids checked with an ohm meter
