Doug Thorley 2003 Toyota Tacoma - 3.4L V6, without smog fittings - Headers Logo
david blackburn Posted on Jul 27, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do i change toyota knock sensor 2003tacoma v6?
Kevin Crompwell
Level 2:
New Friend:
  • Expert 56 Answers
  • Posted on Jul 30, 2018
Kevin Crompwell
Expert
Level 2:
New Friend:
Answers
56
Questions
0
Helped
31123
Points
148
Copy and paste this to YouTube: 5vzfe knock sensor
Where is the crank sensor located on a 06 toyota highlander
images for Where is the crank sensor located on a 06 .
How To Install Replace Crankshaft Position Sensor Toyota ...
? 6:58
https://www.youtube.com/watch?v=M6zU6jh8pNc
Jan 24, 2011 - Uploaded by 1A Auto Parts
How To Install Replace Crankshaft Position Sensor ToyotaCamry 3.0L V6 1AAuto.com ... the crankshaft position sensoron a 1994 Toyota Camry 3.0L V6. ..... 2002-2006 LEXUS ES300 ES330 TOYOTA CAMRY KNOCK ...
Toyota 4runner 3.4 v6engine 1996 knock sensor location
Where is the knock sensor 2 circuit(Bank 2) located on my 1996 Toyota 4 runner V6
I have a 1996 Toyota Avalon XLS V6. Engine light is on and im told i have a bad Knock Sensor. It has 2 and @ $150ea. Is there a cheaper or way to fix or bypass this problem? Ther isnt any knocking or...
i honestly have never seen a knock sensor go bad. a knock sensor detects spark knock,which is from low octane gas. if it hears this then the ecm retards the timing to stop the knock. you wont be able to hear the knock that its listening for. its like a little microphone stuck in the block. before you replace it you might want to check the plugs on the sensor itself. if they are corroded they could cause this problem.. ANYTIME you have engine codes ,always check your ground cables on the engine and the battery. i work in the marine industry and you would be amazed all the codes you can get just from having a corroded battery cable..like i said , i have never seen a knock sensor go bad..
1helpful
I cant find the knock sensor on my 1993 toyota camary v6
The knock sensor is located inside the cylinder block, on the inner side of the cylinders. You have to remove the cylinder heads to see it. In a word, this is a very difficult undertaking.
7helpful
4answers
Need to locate knock sensor on 1999 camry V6. Where is located.
i have toyota windom 4vz-fe i need locate knock sensor
Top Doug Thorley Equestrian Experts
Imagdrider
Level 1 Expert
john h
ADMIN Andrew
ADMIN Andrew
Are you a Doug Thorley Equestrian Expert? Answer questions, earn points and help others
