Question about Euro-Pro Sewing Machines
What size bobbin does the Shark 417 by Euro Pro take?
I have the manual, but it does not give the size for bobbins or needles
  • Euro-Pro Master
  • 7,365 Answers
Try contacting these sites and see if they can help you with the info about the bobbins and needles
sewvacdoctor.com
a1sewingmachines.com
Posted on Jul 28, 2014
SOURCE:
SOURCE: needle will not pick up bobbin threat
I had the exact same problem. The timing is off. You can actually fix this yourself all you need is an allen wrench. If you look at the rod the needle is inserted into and follow it up to about 2 inches below the top of the machine there should be a clamp. use the allan wrench to loosen the clamp and adjust the needle height. I used this website as a guide to getting the timing correct. http://www.sewusa.com/Sewing_Machine_Repair/Repair_Pictures/timing1.gif
now if only I could figure out why my thread keeps getting jammed under the bobbin!
Posted on Feb 22, 2008
  • 106 Answers
SOURCE: Bobbin won't thread
Sounds like the bottom tension is to slack.
Look at the side of your bobbin case, when you thread the bobbin thread part of the route it runs is under a flat leaf spring. There is usually 2 very small scews on this leaf spring one screw holds the spring onto the casing and will be tight. The other is the tension adjuster screw, turn this screw clockwise half a turn at a time. After each half turn pull the bobbin thread until slight resistance is felt. Then try sewing if bunching/tangles still occur more tension is required, this is trial and error until the tension is corrert.
If you want a new manual try this website if your machine is not listed email them and they will try to help.
www.sewusa.com
Posted on Apr 03, 2008
SOURCE: the bobbin thread on sewing machine will not catch
how do you retime
Posted on Aug 13, 2008
geemarie
  • 876 Answers
SOURCE: I purchased a Euro-Pro Shark 998A but the B looks the same
Go to this address
http://www.euro-pro.com/europro/faqdetail.aspx?modelno=998B
It does not list a 9988A, but I would imagine there is not much difference in how the threading and bobbin is done. This is a page of instructions as well as a manual to download. The manual is in Pdf format, so if you don;t hae acrobat reader, you'll need to go to www.adobe.com/acrobat and download it for free so that you can read the pdf file.
Good luck to you and Thank you for using Fix Ya!
Posted on Aug 22, 2008
SOURCE: Euro-Pro Shark Intelli-Sew 9110
you need a new bobbin case, only problem is finding the right one. I am currently wasting hours trying to find one for our 9110 intelli sew which has needle holes punched through it from where it jumps right out. I think lots of manufacturers know fine which parts fit the Euro-Pro but would like all of us to scrap them and go out and buy theirs!
Posted on Sep 18, 2008
I have a euro pro shark sewing machine. I just changed the thread for another project and cannot get the needle to pick up the bobbin thread. Any ideas?
Try installing a brand new needle. Bent/damaged needles will sometimes not pick up the bobbin thread.
Make sure the machine is threaded correctly. Check the bobbin--ie, it is turning the correct direction in the bobbin case and is threaded properly through the bobbin tension.
You might also try pulling the bobbin thread up to the top before beginning to stitch.
How and Why to Bring up the Bobbin Thread
Oct 02, 2016 | Euro-Pro Sewing Machines
NEEDLE LOCKED ON SHARK EURO PRO
Release the screw on the needle. Back up the machine manually. Grab the need head with a pair of pliers and lever the needle upwards until it comes up from the bobbin. Keep it straight or the needle will snap. Strip it down and find out what caused it?
Aug 21, 2015 | Euro-Pro Shark 80 - 7133
Shark 60 needle doesn't go up and down
Is the bobbin winder in the fill bobbin position? If it is then the needle will not go up and down.
Jan 21, 2014 | Euro-Pro Shark 60 - 384
My machine is not picking up the bobbin thread
check the needle to see if it's damaged
make sure to have a 3-5 inch thread tail on the bobbin
then make sure the top thead has a 3-5 inch tail , then hold the top thead with your fingers( away from the needle) & with the other hand use the handwheel on the right hand side of the sewing machine & slowly manually let down the needle into the bobbin area & see if the bobbin thread will come up that way
Sep 26, 2010 | Euro-Pro Shark 60 - 384
I can't get the bottom thread to come up with the needle on my euro-pro shark intelli-sew
try this
make sure there is a 3-5 inch tail on bobbin thread
make sure there is a 3-5 inch tail on top thread, then hold the top thread tail with your fingers (away from the needle) & with your other hand turn the hand wheel manually on the right side of the sewing machine,, slowly letting down the needle down into the bobbin area & see if the bobbin thread will pick up this way
Sep 25, 2010 | Euro-Pro 9105 Computerized Sewing Machine
The needle will not go down all the way, so it dosent sew on my euro pro, 7133 sewing machina
Check the manual to be sure the needle is installed correctly, this is usually with the flat side of the shank facing the back of the sewing machine.
Make sure the needle is not bent.
Also, there may be thread tangled in the bobbin area. Open the needle plate and bobbin; clean away any lint or thread that has accumulated there.
If this does not resolve the issue, the machine will need to be serviced/repaired by a sewing machine tech.
Mar 18, 2010 | Euro-Pro Shark 80 - 7133
Euro-Pro Shark Model 384 - Bobbin winding spindle won't rotate
-Don't know exactly it looks like, but make sure you press the bobbin either back or forward to engage the spindle to be able to spin the bobbin.
Good luck
Mai
Jun 10, 2017 | Euro-Pro Shark 60 - 384
Won't catch bobbin thread
In order to see whether or not my euro-pro 9110 had a timing issue, the service rep had me change out the needle (making sure I was using anything but a Singer brand needle--they do not work in these machines). I re-threaded the needle, took out the bobbin casing and the plastic ring encasing the bobbin, then lowered the needle to see if the hook on the metal ring holding the bobbin actually catches the thread on its own. If it doesn't catch, it's a timing issue and needs repair. They can walk you through this process of troubleshooting and set up repair if need. Call Eruo-Pro's customer service center for sewing machine service and repair at 800-798-7395
Apr 17, 2008 | Euro-Pro 8260 Mechanical Sewing Machine
Sewing Machines Logo
315 people viewed this question
Top Euro-Pro Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you an Euro-Pro Sewing Machine Expert? Answer questions, earn points and help others
