Rheem RTG-74PVN-2 Natural Gas Pronto Whole House, Natural Gas, Tankless Wat Logo
George Colazo Posted on Jul 27, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What does this mean c7 13 - Rheem RTG-74PVN-2 Natural Gas Pronto Whole House, Natural Gas, Tankless Wat
hank5899
Level 2:
  • Expert 151 Answers
  • Posted on Nov 29, 2014
hank5899
Expert
Level 2:
Answers
151
Questions
0
Helped
56558
Points
317
It is the code for the thermocouple or
oxygen depleation sensor call rheem and thay will send
you a how to in PDFs but check the venting first
2answers
I get an E4 message. what does it mean?
I have a model yf-008 110 v 3000w tankless water heater it shows e4 what dose that mean
Hot water runs but heating wont. Pump continously overunning.
What do you mean when you say that 'hot water runs but heating won't' ? Do you mean that water is coming out of the hot water faucet, but that it is cold? When you say pump continuously overrunning, what pump and what do you mean by overrunning? I would like to help you, but I'm not sure what you are asking. Also, is this a water heater, or a boiler?
How to determine the length of a rheem water heater ?
Do you mean size?... height, width, and diameter of a specific model?
Or do you mean the length of warranty coverage. You will need serial number located on label on side of tank.
Or do you mean age of water heater?
Suggest contacting Rheem.com
http://waterheatertimer.org/Water-heater-warranty-by-brand.html
http://waterheatertimer.org/pdf/Find-Age-of-water-heater.pdf
Gene
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
What does code 79 mean for the rinnai RU98i? It is beeiping and flashing 79
There is water leakage internally. Possible tank or water inlet or water entering from the combo air inlet/exhaust pipe.
Rheem model 41vrp40n flashes twice and stops working
Error code means that you have electronic gas control valve.
Copy following link to identify gas control valve, read error code meanings for each, and download service manual relevant to each gas control, but not specifically Rheem since rheem does not post service manuals.
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
The fact that water heater restarts, means that water heater is getting gas, getting sufficient air for combustion, thermister is ok, gas pressure is good, etc.
The fact that you unplug and replug water heater and it works, shows that you have power vent model.
Since water heater worked correctly before, 2 flashes with Rheem power vent model could mean that pressure switch has failed.
Bubbling water at pressure releaf valve on top of valve. valve is rusted. rusty water in pan. Unit was installed new two years ago. Offer suggestions. Thanks
Rusted water usually means anode rod depleted and tank is rusting. Change 570241 anode rod every year or so.
Boiling water could mean bad thermostat causing run-away heating so water is released out of TP valve. Replace 994062 thermostat for 4 gallon.
Leaking water at TP valve could mean bad TP valve: replace TP valve with generic valve from hardware store.
Open link for diagram, parts and replacement information
http://waterheatertimer.org/pdf/Bosch-GL_English.pdf
1helpful
The red light on the water heater keeps flashing
Attached to the water heater is a troubleshooting chart for your sequence light. 1 flash means..., 2 flashes means...., and so forth. Find the chart, count the flashes and see what it means and we'll go from there. Douglas
What does error code C2 11 mean?
code 11 means there is not enough gas
is this a new install?
do you have at least 3/4" gas line to the unit?
Blinking red light no heat
It sounds like you are actually in lock out. Recycle is when during a call for heat, the flame goes out, the unit will try to restart itself. Hope this helps
Top Rheem Water Heaters Experts
Mike Cairns
Mike Cairns
Sean Wright
Sean Wright
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
