SOURCE: Getting Chain back on MX500
I can do it for you because I had to change my rear tire as well and I have done it before and I will do it for you free of charge but I live in Bronx, New York and I have no idea where you live LoL... If anything my E Mail is [email protected]
SOURCE: how do you get the tire of the rear rim of the
i would suggest taking the chain off of the sprocket(cog), then loosening the nuts. then using tire-levers from a bike shop to carefully leve-off the tire. this should work....i have experience with bicycles....i race them! good luck!!!
SOURCE: The chain keeps coming off of my daughters MX500.
The chain usually comes off because it is not tight enough or the chain is not aligned correctly with the sprockets. Check the chain tensioner to see if it is keeping the chain tight and not moving even though it is tight, if it loosens, replace the tensioner. Check the chain for any broken or worn spots or links, if any are found replace the chain.
