Depends also on the kind of tyre.
For the maximum load of tyre nex kinds need next pressure , wich is called AT-pressure/maxloadpressure/reference-pressure , for up to maximum speed of tyre or if lower 160km/99m/h. This is not the maximum pressure of tyre.
Normal car tyre /standardload AT 2.5bar/36psi ( exeptions as low as 2.2)
XL/Reinforced/Extraload AT 2.9bar/42psi ( exeptions 2.8 and 3.0)
6PR( plyrating) /C-load AT 3.8bar/55psi EUR ( USA 50psi/3.4bar)
8PR/D-load AT 4.5/4.8 bar/ 65/69/70 psi
From E -load is not often used in Europe.
From this AT pressure you can calculate the needed pressure for lower loads . Made spreadsheet for it in wich I first add 10% to the assumed load before calculating.
Will give example picture
