SOURCE: Flotec Shallow Well Jet Pump won't pump water
The tank is an air tank, it works like a cushon and accumulator.
Have you reconnceted the pump? If not fill the pipe that goes to the well with water. It should not drain down, there should be a foot valve that prevents the water from running back into the well. So if the foot valve is working it should not take a lot of water to do this.
Pour water into the suction side of the pump until the pump is as full as you can get it, reconnect the pump and start it up. Yes it does need to be primed
Good luck
SOURCE: i have a flotec water pump that sits on top of my
if the pump is working correctly, it can either be, need more water to prime it, or something in the well, such as low water, plugged filter, etc....sometimes when you have a system that is intermittently used, it can take 20 or 30 minutes of continuous priming to get it to pull, enough water to maintain the prime.
SOURCE: 3/4 pump -is pumping water - but a a slow pace
Re prime the pump. Make sure the suction line is completly flooded so it will take a good suction from the well.
SOURCE: Pump stopped working while pumping
Yes, most motors are thermally protected. It is usually bi-metallic, and resets itself.
--W/D--
SOURCE: Flotec pump problem
Thank you for posting your question here on Fixya.com.
No, only a thermal overload. If the unit was hot and has had a chance to cool off it should start. If you have voltage to the motor and it will not even hum or buzz, you need a new motor. The short must have blown the winding open.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Hi Anonymous, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
