Forest River 2008 Flagstaff MAC / LTD 228D Logo
M
Mario Posted on Jul 27, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to replace lead coble on a flogstaff popup camper
How to replace lead cable
Red River RV Repair
Level 2:
Sergeant:
  • Expert 405 Answers
  • Posted on Jul 29, 2014
Red River RV Repair
Expert
Level 2:
Sergeant:
Answers
405
Questions
0
Helped
164129
Points
581
There should be a metal channel running from front to back down the center if the trailer under the bottom of the trailer. There will be a pipe coming from each corner and connecting to this channel. Disconnect the four pipes from the center channel. In each pipe will be a heavy gauge spring type pusher (this is what actually raises the roof), pull each of these out of the center channel. Next you will need to remove the rear pulley from the bracket. This should be accomplished by pulling a hairpin keeper which will then allow the center clevis pin to be removed which will free the pulley. Next you will disconnect the cable from the winch drum. Now you will pull the cable free from the lower half of the center channel (If you look into the channel you will see that there is an upper and lower section). Once the cable is free from the lower section you will pull the cable free from the upper section. NOTE: The cable will be covered in grease and will be messy. Were rubber mechanics gloves or use rags to minimize the amount of grease on your hands and clothes. Now you are ready to install the new cable. Feed the cable through the upper portion of the center channel once it has cleared the rear end of the channel start to feed it into the lower channel. Now you can reinstall the lower channel push springs. This will help to determine how much cable should be in the channel. Next install the upper push springs. Now you can reinstall the rear pulley and last you can connect the new cable to the winch drum. The new cable will have a crimped lock with an oval washer at the end and another in the middle which will engage the push springs. The entire process should take about an hour and a half (rough estimate based on having a clean work shop, the proper tools and some mechanical abilities). Do NOT attempt to fabricate your own cable! It could lead to someone being seriously injured. If you need the main cable email me the year, make, model and overall length of the camper and I can get you a price. [email protected]
How do you empty the fresh water tank on a Jayco Jay 806 popup? There seems to be no low point valves.
Look underneath the camper for a drain valve. Never seen a Jayco without a factory installed drain valve.
Jul 01, 2019 • RVs
1helpful
What is the amperage for a 2009 Fleetwood Westlake Destiny?
Pop up campers are going to either be a 20A or 30A. If the cord on the camper looks like a standard house plug, it is 20A. If it is a larger, round connector, this will a 30A plug. The good thing about these various plugs is that they will only fit in the right connectors on the electrical pole at your campsite. So just plug it in where it fits. If you need to replace the cord, look at your campers fuse panel and see what the main fuse is rated for.
Jun 27, 2019 • RVs
How to light the oven on a wedgewood t-2122 in a1970's popup camper
Use a long neck lighter. Place the flame under the oven's thermocouple, then turn the oven to "pilot" or "light" until the flame will stay on.
Once lit, turn to the desired temperature and enjoy. Make sure you have a fresh air supply such as a roof vent open, along with your hood fan running anytime you cook with gas indoors.
Jul 20, 2016 • RVs
2answers
I want to replace canvas on jayco camper
take the camper to a jayco service center and get the correct replacement items for that camper
then it is a matter of removing all the fitting strips to allow removal of the old canvas and the fitment of the new items
a clue her is to when the new canvas id fitted is to leave the camper opened up and to wet the new canvas with silicon fluid and allow it to dry put before folding it away
why , it stops water coming through the canvas when touched in the rain and prevents mould if folded away when wet
How do i find the right replacement vent cover for a 2001 Starcraft Genesis camper?
Just measure and be sure the measurement fits the hole you have for the vent. There is no standard for anything.
Oct 12, 2014 • RVs
Owners manual for 1997 flagstaf popup camper
You will have to contact Flagstaff, but you also need the actual model number of your camper. You can also google a manual for a 97 Flagstaff model # _______
Sep 13, 2014 • RVs
What is the part called that is sewn into the bottom of the vinyl on a popup camper that attaches the vinyl to the bottom. Also where can I find this product?
Channel slide attachment or snaps. Found on line at camper world or at a local camper world retail store. You could also try to see if the manufacturer is still in operation and get it there.
Aug 13, 2014 • RVs
Top Forest River RVs Experts
Renee Knafel-Bullock
goneforever.
Are you a Forest River RVs Expert? Answer questions, earn points and help others
