Have a burnt 3 phase motor that nameplate is RPM 3450 230/460V PH 3 AC Motor And want to replace it into RPM 2800/3500 200-230/380-415v ph 3 Multistage Turbo Blower I wander what rpm would be of the to be replaced motor that sticker marking is 380v 50Hz if i connect it into 220v or 230v? What would be the advantage or disadvantage of using a motor that 380 volt connected into 220v or 230v. I tried to connect it at 230volt and it runs good. Thanks in advance.
SOURCE: How To Convert Y Connection 3 Phase Motor Which Burnt Into A Delta Connection?
Delta is entirely different connection.... look here:
https://www.google.co.uk/search?q=3+Phase+Motor&es_sm=122&tbm=isch&tbo=u&source=univ&sa=X&ei=TWKZU9jpJobSOe3lgdAD&ved=0CEMQsAQ&biw=1534&bih=846
