Error Code 15: OC Driver Error
This error occurs when the Mechanism Control ASIC detects that a
single phase of the OC Motor was energized for longer than the allowed period of time. This indicates a malfunction of either the HCPP motor, or ROM Board driver circuitry (TA10: STA485A), or both.
1. Check OC motor connector CNO/C on the Sensor Board.
2. Check both the OC motor and the OC motor driver circuitry on the
ROM Board. To replace the ROM BOARD If necessary, replace the OC MOTOR
SOURCE: DFX 9000 error oC
09 : FAN1 driver error
0A : FAN2 driver error
0B : FAN3 driver error
0C : FAN4 driver error
SOURCE: PROBLEMA IMPORESORA EPSON DFX-9000 ERROR 3
Aprendizaje hablar español
ERROR 3 - Carriage Return Horizontal Position Error
The SP motor brake signal did not switch ON within 3 secs after turning the printer ON.
La señal del freno del motor del SP no encendió en el plazo de 3 secs después de girar la impresora.
Check SP motor connection or call for service.
Compruebe la conexión o la llamada del motor del SP para saber si hay servicio.
SOURCE: Epson dfx-9000 printer is showing error 0D when it is switched on
check print head built in thermistor and the carrier cable.
SOURCE: error 01 0n epson dfx 9000
i have a problem on my printer epson dfx 9000 with erro code 01 turn off your priner any one with solution?
