Question edited for a lot more clarity. All question need FULL 'make model (what it is)'.
Question moved from 'Power Computers' to Lowrance.
Your problem is in the boat. You either have a bad electrical connection, or a bad connection TO the transducer or the transducer itself is faulty. You can return the transducer under warranty or return it for testing. It is unlikely to be the internal memory IMO.
Lowrance has started using the same power cord on their Elite units and their HDS units. The yellow wire on the power cable is an accessory wake up wire designed to be used in conjunction with the structure scan modules for the HDS.
You can simply tape this wire off during your installation ND ignore it.
Just type this into your browser's searchbox. manualslib.com/manual/292954/Lowrance-Elite-5-Dsi.html
You should be able to pull up the manual there.I just did. Garcuda
The additional wires are for NMEA data transfer to and from other devices and sensors like distance, speed, depth, temperature and NMEA 0183 sentences the unit will use when connected to a VHF radio or other NMEA 0183 device.
