Computers & Internet Logo
A
Anonymous Posted on Jul 26, 2014
How to config Wrt160N Router - Cisco Computers & Internet
Prashant M
Level 3:
  • Cisco Master 2,278 Answers
  • Posted on Nov 25, 2014
Prashant M
Cisco Master
Level 3:
Answers
2278
Questions
Helped
978516
Points
6246
Connect the computer directly to the modem. make sure that you can access Internet directly connected to the modem.
The connect the modem to Internet port on the router and computer to port 1 on the router.
Open the Internet browser and in the address bar type 192.168.1.1 .This will open the setup page of the router. using this setup page, you can configure the router manually.
Check this link for
Manual setup of Linksys WRT160N router
blackbelt555
Level 2:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 96 Answers
  • Posted on Jul 27, 2014
blackbelt555
Expert
Level 2:
Cheetah:
Answers
96
Questions
Helped
13013
Points
140
192.168.1.1 usually. or 192.168.0.1 hope this helps
2answers
1helpful
Error 322
Are you trying to run the CD that comes with the router?
I think you can try to setup your router manually instead of running CD. WRT160N router has issues with the firmware so I will suggest you to upgrade the firmware of WRT160n router first.
See how to setup Linksys WRT160N router
How do i change my connection from unsecure to secure?
the least you can do is set WEP key( in router config) to access the wifi router/AP ( access point). this will prompt client/s to enter password/key if they want to access internet via your router.good luck
How can i set up my wrt160N? please help
Here, go to this site and it will give you instructions on how to configure you linksys wrt160n router
http://www.wikihow.com/Configure-a-Linksys-WRT160N-Router
Hope i help. please rate my solution thanks.
The router will work for about an hour and then our Wi-Fi will quit working. If I power cycle I get another hour or so of Wi-Fi then it drops off again.
Flashing the router usually works. Changing it to another frequency might help as well if there's interference on the band it's set. This is all accessible via the router config page.
Also, dirt and heat affects your router's performance, cleaning off the dust might help out
Reset the router now print and ladtop dont work
you need to config. router (WPA, ADSL Connections,....),you must have some router config backup.
Cannot get wirelss connection through my WRT160N wireless router. Was working and now not. I can get internet connection through the LAN ports so I know that the router is working with a fixed cable
by default ip address of linksys is 192.168.1.1
to star config you need to be connected with ethernet cord rj-45
or conenct via wireless by conencting to linksys on wireless
admin user: blank
admin pws: admin
*choose a protocol on your linksys router on internect conenction type:
check isp protocol :
dhcp: needs serail number of mac address
it picks up automatic
pppoe: needs username and pws from isp
*the ip address has to be diferent from the isp modem:
isp modem 192.168.1.1 linksys 192.168.1.1 incorrect
isp modem 192.168.1.1 linksys 192.168.2.1 correct
change the ip on lan settings on your router
*wireless: ssid by default is linksys
ssid: linksys
wep : none
to setup wireless
access the wireless basic
change the ssid to any network name
enable the wireless password
choose wireless security
enable wep key 10 digit hex pws
make shure you saved settings on every setting
I had a earlier problem with my wireless network adapter in my laptop not fully installing. I bought a driver program and now I should have the most updated driver and the driver is working. my continuing...
To configure the wireless router and the laptop's wireless card, follow these steps : -
1. Connect the wireless router to your computer with a LAN cable.
2. Start your browser and enter the router's configuration URL
3. Enter the router setup, login and password
4. Change the admin password
5. Go to the wireless settings and change the default SSID and turn off SSID broadcast.
6. Setup encryption key the strongest is WPA2 (if not then WPA).
7. For further security measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router.
8. Record the settings you have made and keep it in a safe place and Save the settings.
9. Configure the wireless cards on the computer/s with the SSID and encryption settings of the router.
10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router.
I have an issue with trying toset it up, i
its very easy if u put the cd and followed the steps, first of all put the cd while u still connected to the modem, then folow the steps. u will end with your computer connected to the router and ur modem connected to the router, let me know wat is ur problem exactly so i can help you. Regards
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
Limited or no connectivity to the internet. my setup: the telephone port is approx 30m from where i need internet access. Originally I had a dlink wireless router set up but was connected via cable, now...
On which port of the D-link router did you plug the WRT160N router?
Do this setup.
Disconnect the WRT160N from D-link.
Connect a computer to port 1 of the WRT160N. Access the setup page by typing 192.168.1.1 on the address bar. you may need to type in the username and password for WRT160N. on the setup page Change the LAN IP address from 192.168.1.1 to 192.168.2.1. save the settings.
Connect a cable from port 1,2,3 or 4 of the D-link router to the Internet port of the WRT160N. turn off everything then turn them on starting from cable modem>D-link >WRT160N then computer.
You should be able to access the internet.
Top Cisco Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
