No image, blinking blue light only, no self test image
Here's some tricks I would try...
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or orange or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
7. Also, you could try your display on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers.
Good luck.
SOURCE: samsung lcd 913v self test ok, no image when vga connected
This problem often occurs in samsung SyncMaster LCD monitors.
The
solution is open your look for the LCD monitor power supply module
(which have PCB connector to the AC power), on that board look for
capacitors, now look for broken one which upper part is bloated, like
the image below:
If you find a damaged capacitor as in the picture then you should replace it with the same value.
SOURCE: samsung syncmaster 913v has no image power light flashing
replace capacitors 1000mf/25v 470mf/25v...
SOURCE: when I turn on the monitor all I get is a blinking
I would suggest to try it on another PC first to narrow down the problem before taking h monitor apart.
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG and other monitors to get some ideas what goes wrong: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.badcaps.net
http://en.wikipedia.org/wiki/Capacitor_plague
SOURCE: My Samsung SyncMaster T220 does not display
m_r_murphy, The T220 may have developed an internal ac to dc "switch-mode-power-supply / CCFL inverter supply" power problem an you may need to need to have it repaired, Look into warranty or outside technician to refurbish the unit's SMPS/inverter!!! From your description, I believe that the SMPS is in "partial shutdown" mode!!! (no 12 to 14v dc) to power-up the "cold-cathode-fluorescent-lamps" that enable you to see the text and graphics that you already know are being displayed on your lcd panel!!! (+5vdc or 3.3vdc rail still alive!!!) You have "black screen" symptom!!! NOT BLANK n BLACK screen!!! There are lots of DIY videos on YOUTUBE to help you decide if you can attempt a cheap (<$20usd) repair to your unit. Do some reading in my old fixya profile (louie12fix) and visit some of the links you find there. Because your T220 isn't any different than any other brand of CCFL back-lit lcd display in it's basic design and operation you should be able to fix it. Get back to me lmistyrel on aim or do additional comment to this original post here on fixya with info on your next step to repair this unit.
All the other ccfl back-lit lcd monitor tech's on fixya already know what's wrong inside your unit!! Do your research first!! Bye for now, 12fixlouie
SOURCE: Samsung Syncmaster 943b light blinking
try to connect monitor with other computer, this way u will confirm weather the fault is in monitor or in computer. if it is in monitor, check for bent pins in connectors which connecting computer & monitor, firmly connect both ends of connecter & tighten the screws. if problem not solves then u need to replace main board of monitor.
