If it is getting HOT and no water dispensing > Make sure water out let spout is CLEAN and clear.
what can i use to clean or add to the water to clean it ?
ill check that out right now! THANKS
AWESOME NOW BREWING LIKE A PRO ! ONCE I ADDED VINAGEAR IT STARTED FLOWING LIKE A RIVER.
Thank YOU HAVE A WONDERFUL SUNDAY
SOURCE: I have a Bunn VPR, it brews fine for a couple pots
Try running a quarter-pot 50/50 solution of white vinegar and cold water through to clean out calcium deposits in the pump system. Use a clean filter to catch the pumped debris. When pumped through, let cool somewhat, and reuse the cold mixture again twice more. Pour out the vinegar solution and run several cold water loads through to wash out the taste. Hope this helps!
SOURCE: my pour-omatic steams up overnight then will not
Check the thermostat on the machine, make sure pot is full before brewing. The water in the tank just heats up it is loosing most of it, make sure lid is on pour in screen.
SOURCE: my bunn pour- omatic only gives warm water --any suggestions?
TRY RUNNING WHITE VINEGAR THREW THE TANK, IT MIGHT BE ALL CALCIFIED AND THIS IMPEDES HEAT TRANSFER .. MIGHT NEED TO DO IT A FEW TIMES , DO IT TILL THE WATER IS CLEAR. JAY THE PUMP GUY FL
Testimonial: "I tried this-- after 1 tankful water was very warm, so 2 morrow I will give it some more vinegar and if it makes a big difference the I will be more tankful. thanx Jay--much thanx"
