Just need codes for the orion tv
0028,0022,0021,0000,0027.
Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes used for devices too are given, in the order of device brand name list in alphabetical order. Do a search by type in the brand name of your device, at its search box, and press "Enter". Or, pull up older posts.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
SOURCE: Need universal remote code for ge remote and Orion tv
The code that worked for me was 135.
Other Orion codes are 035, 121
Four digit codes for newer remote models might be one of the folling.
0236, 0179, 0463
Good Luck!
SOURCE: durabrand tv model#BH2004D need code for GE universal remote
For the GE Universal Remote (RC24991-b), 0157 works (for me) with this Durabrand model
SOURCE: ge universal remote code for a sv2000 tv
I need to know how to program a sv 2000 tv with a rca universal control
SOURCE: remote code orion tv/vcr # tvcr0950bw
I had a bugger of a time trying to solve this exact same problem. I went through 3 universal remotes before I found a winner. Using the Jensen Surf Series SC-340 I managed to figure out the code for the vcr to be 687. This is not listed in the manual that I looked up for the remote, probably because the remote was made in 1997 while the tv/vcr is 1998. After trying the ~30 codes in the manual I set the remote to auto scan for the code. After 30min scanning for the tv code I switched over to scan for the vcr code. Three minutes later I get the code and that "Oh yeah. Who got this bad boy to work? You did! That's right!" kinda feeling. I hope this helps.
TLDR: I got a Jensen Surf Series SC-340 Universal Remote to work with the tvcr0950bw using the code 687 on the vcr.
Visit the site named 'Electro-help' for more
details. Click this link. View it in
"Timeslide" or "Flipcard" option, which can be selected
from the drop down box menu by the [Sidebar] tag, at the top left corner
of the display window. You can also
click the [Home] tab to the latest updates. It will make search easy.
There are more than 1300 posts to different brand TVs now. Pull up older posts
there.
