Abs and brake lights on 2001 chevy suburban - OEM 2001 Chevy Suburban 1500 Radio / CD Player vly5979d AM-mono-FM-stereo-CD player "UN0" or "UP0" Birmingham, Alabama
? 24:15 https://www.youtube.com/watch?v=Jo76ylqgUR8
Dec 22, 2012 - Uploaded by Skizzot7
This is how to fix intermittent ABS and Brake dash lights on all Chevrolet ... That board is rather robust and is installed external to the vehicle in a location that sits .... I took the module out of a2002 Sierra and it is engineered with no T10 .... ABS Sensor and Harness 2000-06 Chevy Suburban Tahoe GMC ...
have the system scanned, there are a lot of things that can cause the lights to turn on and only a scanner that can read ABS will be able to pinpoint it.
Your dealing with OBDII
I am dealing with OBDI "93 Caprice Classic"
***I have been told***
The code is read from the ABS light on the dash
If it blinkes 3 times and stays on, Bad ground, if it flashes more then that it's a bad sensor and the count will give you the bad sensor.
Unfortunatly mine blinks three time and I have not found the ground wire yet.
Good luck
what you have is a ABS module that has shorted out internally. you have to replace that module and then bleed the ABS pump AND the brakes at all wheels.
One of the sensors has gone bad and needs to be replaced, the other thing to that would also do that is the ABS sensor is dirty or needs to be re gaped to the speed ring on the hub.
There was a issue bulletin with your Tahoe on the ABS activating under 8 km/h.
Good luck and hope this helps, if not clean out the sensor with brake parts cleaner and check the wire harness and ABS sensor bracket. Re gap the sensor to the speed ring hub. Here is the bulletin.
Anti lock Brake (ABS) Activation at Low Speeds (Clean Wheel Speed Sensor Mounting Surface) #03-05-25-007C - (05/16/2006)
2001-2006 Chevrolet Suburban, Tahoe
the red brake warning light will usually indicate low brake pressure,abs light can come on also,check fluid level,does brake pedal become soft and spongy?if so it can be the brakes master cylinder,if fluid level is low,can be a damaged brake line,inspect brake system,
