Simple solution: switch two of the wires. Doing so will reverse the direction of the motor. You can switch it at the motor or on the electrical plug end.
Motor wiring- Capacitor usually gets two brown wires, 120 Volt Black= Power, White neutral. 220Volt usually no white Black =L1 Power, Red,Blue, Speeds. Yellow=L2
Normal wiring for this type of 9 lead motor to 440VAC is
Connect #4 to #7
Connect #5 to #8
Connect #6 to #9
Connect supply phase A to #1
Connect supply phase B to #2
Connect supply phase C to #3
Can you confirm the CAT and SPEC numbers? They do not show up on the Baldor site. If they are correct as listed, you need to call the Baldor help line and find out if this is a special motor.
drop down menu "service" click "service literature" click "old target, dimas, partner literature" enter model number pdf has basic wiring diagram page 4 or so
