If the leak is: 1. in the fuel line it should be replaced. new lines with hose clamps. 2. If leak is from the carborator, the float may be stuck. Remove and inspect the float, being careful not to alter adjustments. Clean bowl with carb cleaner and replace. Be careful of the gasket installation. 3. The needle valve may need replacement. Check the tip for wear.
Alot of times somethig was in the tank and reached the needle and cleaning will solve the problem.
Engine will
not start
1. Low on fuel or oil. 1. Add fuel or oil.
2. Ignition switch in "Off"position. 2. Turn to "ON" position
3. Faulty spark plug. 3. Replace spark plug.
4. Choke in wrong position. 4. Adjust choke accordingly.
5. Fuel shut-off valve in closed position 5. Open fuel shut-off valve.
6. Unit loaded during start-up. 6. Remove load from unit.
7. Spark plug wire loose. 7. Attach wire to spark plug.
where is carbuerator on portable generator?
