Euro-Pro 9105 Computerized Sewing Machine Logo
A
Anonymous Posted on Jul 26, 2014
When i go to sew the needle won't move - Euro-Pro 9105 Computerized Sewing Machine
Ruth summersides
Level 3:
Genius:
  • Euro-Pro Master 1,493 Answers
  • Posted on Jun 03, 2015
Ruth summersides
Euro-Pro Master
Level 3:
Genius:
Answers
1493
Questions
Helped
363375
Points
2425
My baby lock lock up while sewing the needle want move up and down it is a grace it says error 6 can you help me thank you
Sewing Machine: Needle won't move
A disengaged clutch, broken drive belt or internal drive gear failure can prevent the needle from moving. Engage the hand wheel clutch if you have it disengaged for bobbin winding. If the needle won't move with the clutch engaged, unplug the sewing machine and check the drive belt.
https://www.searspartsdirect.com/diy/symptom/sewing-machine-repair/1234596/needle-won-t-move/smac1011147
How to Fix Brother Sewing Machine Error Code E6 Q: What does E6 error message mean? A: The motor locked up because thread is tangled Q: How to fix E6 error message? A: Do the following:
  • The upper thread could be tangled. Remove the upper thread and any loose threads. Raise the pressure foot, raise the needle to its highest position and rethread the machine.
  • Remove the bobbin and bobbin case to clean any lint or loose threads. Install the bobbin case so that the projection on it aligns with the spring. Then install the bobbin into the bobbin case.
  • The needle could be bent. Replace the needle making sure the flat side is facing the back.
2answers
My 1630 needle won't move down
Hi Peg.
go to this link and have a read up.when you go to this link if a link opens on the right had side asking you do you want help just close that down and you will be able to see what is being said on what it could be stoping your needle moving.hope this helps.
have Bernina 1630 have been sewing lot the last couple
or you could try this link as well.
sewing machine 1630 needle won move down Google Search
Hand wheel won't move.Scissorbutton wont work.
Repairing a Janome or New Home Sewing Machine ...
www.thriftyfun.com/Repairing-a-Janome-or-New-Home-Sewing-Machin...
Question: Memory Craft Machine Won't Run ... I'm a computer repair technician and good with tools, is this something I could fix or should we .... machine which will zig zag fine if i turn the wheel by hand or sew very slowly; as soon as I speed ...
Janome won t turn Sewing Machines Questions & Answers ...
www.fixya.com > Forum > Tags > won t turn > Sewing Machines
Janome sewing machines won t turn related questions and answers. ... Ad. Question about Memorycraft 6500P Computerized Sewing Machine ... it could be a part has worn or broken, esecially when the hand wheel won't turn,, it needs to be.
Janome wheel not turning Sewing Machines Questions ...
www.fixya.com > Forum > Tags > wheel not turning > Sewing Machines
Janome sewing machines wheel not turning related questions and answers. ... 10000 janome jamming fly wheel won't turn fly wheel won't turn warning for too thick ...the hand wheel is not moving the needle at all Hi I was unable to move the needle at all ... Janome Memory Craft 9000 Computerized Sewing Machine.
I have a New Home XLii and the needle position won't move from left to middle to right.
the machine may need to be serviced to see why the needle position won't
move
1helpful
My Singer 5050 sewing machine won't let me
sounds like a part is damaged or jamed, the machine needs to be checked
to see what's wrong with it
Needle sticks on sewing machine and motor won't move it forward
Copy & paste into your browser: http://fixsewingmachine.com You need the free diagrams & details provided on their web site. Jimmy
2answers
Needle won't move
I had that problem too! I usually turn the tension knob and it works,
Top Euro-Pro Sewing Machines Experts
Mike Cairns
Mike Cairns
k24674
ADMIN Andrew
ADMIN Andrew
Are you an Euro-Pro Sewing Machine Expert? Answer questions, earn points and help others
