I have an LG phone.
Dear User,
Please go to settings and do a factory reset and then try. probably your network problem will be solved.
otherwise follow instruction:
switch off mobile and remove SIM card.
Switch on mobile and type *2945#*# it will appear menu go to no.6 which is factory reset and click ok. it will hard reset your device.
and then check if the problem is solved.
if still contain problem that mean it is a hardware problem. please submit to expert technician for assistance.
Regards.
SOURCE: i want to unlock my phone, or get better towers,
I have unlocked a few lgs so it can be done. And vodafone have a new signal booster that is exactly for your kinda prob, however its not free. Check it out in store. If you need unlocking help, get in touch and i will try my best for you.
can u brief ur prob so that i clearly get ur issue.....
SOURCE: My TRACFONE Lg 800G keeps saying emergency call only when I have full service
This problem shouldn't really have anything to do with the signal your getting. the emergency calls only mode is intended for prepaid phones without minutes or contract phones that are deactivated.
That being said, there have been a lot of problems with the 800g sending certain types of data over networks, since your prepaid phone is constantly sending data regaurding your prepaid time, it may just be that the data isn't being sent or recieved properly thus either your phone or the network thinks you are out of time. try taking out your sim card see if you can tell if it is an ATT sim or a T mobile sim, if it's ATT its a pretty good possibility that that is your problem. Either way if your getting the emergency calls only screen and you've got plenty of minuts on your phone I would contact tracfone and tell them what's going on.
and a little FYI: they may try blaming it on your cell number, if you've had the same number for a long time and havent had any problems, dont let them bully you into getting a new number, chances are it wouldn't help anyway
