Frigidaire 14.1 cu. ft. Upright Freezer (FFU14K0DW) Logo
A
Anonymous Posted on Jul 25, 2014
Why are the sides of my frostfree freezer so hot
marlin siecinski
Level 2:
Prodigy:
An expert who has answered 500 questions.
  • Expert 512 Answers
  • Posted on Jul 27, 2014
marlin siecinski
Expert
Level 2:
Prodigy:
Answers
512
Questions
Helped
160401
Points
715
The sides is were the condenser is it is called a hot wall condenser try to keep things from the sides so it can run more efficeiant
Why are the sides of my frostfree freezer so hot?
check to see if you have a fan down by the compressor if so make sure it is running. if no fan you are starting to loose freon
Frigidaire upright frostfree freezer stored several years unplugged, restored power last night alarm keeps ringing and freezer is not getting cold.
Clean the unit entirely, coils, filter, etc. Then retry. You might have a faulty control board since it has not been used in many years. All depends on the location and humidity. That can tear up a thermostat and control board.
Frigidaire upright frostfree freezer keeps icing up, needing to be defrosted. whats wrong with it?
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
1helpful
Leaking water on floor
The defrost drain is most likely frozen or clogged. I put together some instructions on clearing this for refrigerator/freezers and it applies the same to all freezers with drains. Take a look and let me know if you have questions.
http://www.fixya.com/support/r4686046-water_leak_from_freezer_ice_freezer
Same as post in Dec 09, I have water freezing at the bottom of my frostfree upright freezer (whirlpool).
Could be the drain is blocked, Otherwise the water would drain away and evaporate from the compressor unit.
2helpful
Water in bottom of freezer
the drain needs to be check for any kind of blockage. if the drain is blocked or frozen over this needs to be cleared
1helpful
2answers
Frigidaire/electrolux frostfree stand up freezer occasionally seems to completely stop working. Even semi defrosts and leaves some water on floor. after a while it starts up again.Is there a problem here?...
I've had the same problem with my Frigidaire/electrolux frostfree stand up freezer. It's a major downer to go into your freezer to find all of your frozen foods (much of it expensive meat) - defrosted, some or all of it ..ruined. I sometimes wonder how many times it may have stopped working without us knowing, (since we sometimes go days without needing to open it) and just how creepy some of the meat that I am serving my family might be.
On top of destroyed groceries, the cows and chickens lives lost in vain - (aka wasted meat - I'm sensitive to that as the vegetarian in the family), it gets extremely hot on the outside when this occurs. It gets so hot, that we're actually worrying about a fire. It's almost like it is periodically overheating and going into an auto-shut down mode.
Needless to say, we are not "digging" our Frigidaire/electrolux frostfree stand up freezer.....
We are considering ditching it and buying some other model - refurbished. This just stinks... is disappointing... we paid a ton.. and now it's headed for a landfill.... (really?) JUST LOUSY!
Would LOVE a solution.... would love to know of others with this problem...
Sep 16, 2009 • Freezers
Frost in frostfree freezer
Make sure your rubber seal around the inside lip of the freezer is clean and sealing properly! this can be the first cause of frost !
1helpful
Servis frostfree fridge freezer
Hi, I had that last year - It was the control board!
Oct 24, 2008 • Freezers
Maytag Frostfree Freezer ice at bottom
hi thanks for the question .The drain tube is clogged up. Pull fridge away from wall, remove back panel, clean all coils. let thaw 24 hrs. find drain tube by drain tray clean tube to freezer thanks the appliance doc
Sep 28, 2008 • Freezers
Top Frigidaire Freezers Experts
ZJ Limited
ZJ Limited
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
