Paul Hamilton May 20, 2019 hyjacks year 2014
your are installing and OS are you, and is a corrupted DVD install disk from whom or the HDD is bad and corrupting files
or is currently infected and you attempt to install update your OS and failed, right>?
here is the answer. you posted no OS used, or wanted. so.... really impossible hyjacking vague posts no? start your own posts an use your facts (all ) all facts good and bad, both , wins.
a dead PC is all we know.(and bad files)
https://h30434.www3.hp.com/t5/Notebooks-Archive-Read-Only/TFGHT-is-missing/td-p/4971045
the switched models PS, from cq57 (2011)TO
Compaq Presario in C301 (2013 made)
SOURCE: hp compaq Presario CQ57 Notebook PC wireless button has a red light and wireless not working
RESTORE YOUR COMPUTER! This just happened to me and i looked up and tried EVERYTHING! Since my wifi button had only stopped working 2 days ago, I restored my computer to 4 days prior because I was told that sometimes without you even knowing you allow stuff to get on your computer whenever you get online which could cause your computer to turn functions off automatically. My wifi button actually stopped working after I went into a mcdonalds with my computer an used their wifi so I think me allowing their wifi onto my computer did something to it because when I took it home the button was just red altogether and it was SOOO frustrating. But as soom as I restored it, my computer came back on and a little window popped up saying "Your wifi is currently off, toggle your wifi key to turn it on/off". I was so happy! The simpliest thing that no one would ever think of.
SOURCE: AFTER COMPRESSING MAIN DRIVE, TFGHT
Compressing the main drive using a Windows Programme, shouldn't give any problems.
I don't understand what you mean by TFGHT. What is that?
Using the compression utility, can de-compress as required, try running it again and decompress it noting what error messages are displayed, if any. Then try again, when it has recovered, or fit a larger Hard Drive maybe?
SOURCE: compaq presario cq57 PCI drivers
Use a computer with Internet access to download the drivers and then copy them to an USB memory stick. You then insert the USB memory stick inti your Compaq and install the drivers.
You can download the device drivers from the Compaq/HP WEBsupport/download page. Make sure you select your model laptop and the Windowsdrivers you require and install them. Click on this link to download thedrivers: -
www.compaq.com/country/cpq_support.html
SOURCE: compaq presario fan stopping
Take it back to the place of purchase since it is under warranty, otherwise you will damage the processor which the cooling fan protects.
SOURCE: Compaq Presario CQ57-229WM Hard Drive Replacemnet Instructions
How old is it did ou call up and see if it was u.Der warranty if so they will send out New one.....if not remove battey and the bottom two covers with little symbols on them to gain access to he
Hi Anonymous, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
I have a Compaq presario in 301 excuse me c301 NR it has a tfght is compressed when you turn it on it won't go any further
