I NEED THE 4 DIGIT CODE ON THE GE UNIVERSAL REMOTE CONTROL PLEASE
0286,0261. Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes used for devices too are given, in the order of device brand name list in alphabetical order. Pull up older posts.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
SOURCE: Sharp Aquos 32"
TV is under warranty. Get a tech to look at it. It could require a new IR sensor, a firmware upgrade or a system reset that only a tech can do called an Industry Initialization that is in the service mode only
SOURCE: lc-46d43u aquos lcd tv
The remote code 31 worked on my Motorola cable box.
The REmote is for a Sharp LC-32GP1U
The code was listed under one of many for Jerold. I entered codes one by one testing the secondary power button each time.
Code 31 works fine.
SOURCE: lost access to control SHARP TV
Unplug your unit and plug it back in after 2 minutes. When you plug it back in, try to use the remote to turn it on and see what happens. Good luck to you
SOURCE: what is the philip universal control code for
try these
002 013 014 111 502 712 812 813 913 918
if none of them work you will have to try all codes one by one.
Check this link out for more info
http://www.universal-remote.net/philipsmagnavox.html
Good Luck
SOURCE: I need the code for my "sony" universal remote control
SI esta utilizando un remoto marca phillip solo daja presionado code la luz se encendera luego pincha tv y con el botton de cambiar canal le das up varias veces hasta que el tv cambie de canal y luego le das enter y listo
