Hi i was messing around with my iphone last night and i think I migh have by mistake put set it to have an passcode lock and now it has disabled my iphone and I can't use it at all my iphone was working all week expect last night by me mistakenly did something to it
How to Unlock iPhone with Forgotten Passcode
The easiest and most recommended way to unlock iPhone without passcode is using a third-party iPhone unlocking tool dr.fone Unlock. It not only can help you easily to remove iPhone passcode, but also to remove Apple ID and iCloud account from a any iPhone/iPad/iPod without password.
LEARN MORE
You're suggested to take an iPhone passcode removal, like Joyoshare iPasscode Unlocker ( https://www.joyoshare.com/ipasscode-unlocker-for-win/ ) to remove passcode from your locked iPhone screen. It can well support 4-digit passcode, 6-digit passcode, Face ID and Touch ID.
You can simply follow the steps below:
1. Connect iPhone to computer.
2. Select iPhone in iTunes "Devices" and click "Summary".
3. Click "Check for Update" to see whether there is a new version for iPhone software.
4. Click "Restore" and follow the instructions to complete the restore process.
5. Choose "Restore from iTunes backup" when iOS Setup Assistant asks to set up your iPhone.
Or refer to the source page: Forgot iPhone Screen Lock Passcode How to Recover Lost Data on iPhone...
SOURCE: My iPhone is disabled for 4,566,757 mintues, HELP!
The only way is to reflash a new firmware and wipe the code as well as the phone clean.
To do this start itunes on your computer. Then connect your phone to the computer. Once itunes detected your phone hold the POWER and the HOME buttons down at the same time for about 10 seconds. Once the phone flashes off, let go of the POWER button and keep holding the HOME button until you see a message on the itunes telling you that your phone is detected and needs to be RESTORED. Follow directions and it will do its job. I appreciate your positive vote. Thanks
SOURCE: iphone disabled to "connect to itunes" but needs passcode
Turn your phone off and plug it into your computer holding the home button down. That will put your phone into restore mode.
http://www.mobileease.co.uk
SOURCE: i forgot my passcode and now my iphone is disabled.....
how do i find out what my passcode is
SOURCE: i forgot my apple iphone
Try the Restore procedure from iTunes If you have problems. But first try the recovery procedure.
1.
Disconnect your iPhone cable but leave connected the other USB end to the computer.
2.
Turn
off your iPhone holding the Sleep/Wake button. The red slider bar
appears. Slide the bar and wait until the iPhone turns off. Or you could
hold the Sleep/Wake and Home buttons at the same time until the iPhone
turns off.
3.
While pressing and holding the Home button
connect the USB cable to your iPhone. It should power on. Hold the Home
button until you see the "Connect to iTunes" message. Open iTunes if
necessary. You should see the "iTunes detected an iPhone in recovery
mode..." alert screen.
Choose " Restore"
SOURCE: my iphone is disabled
Hi, what is the generation of your iPhone? Your iPhone is disabled because you tried to unlock it but entered the password incorrectly too many times. You can restore your phone in iTunes then jailbreak to unlock. Please provide more information about your iPhone.
