How do you remove coffee bean container from Miele CVA615?
There is set-screw that holds the cofee bean container from pulling all the way out. Loosening almost all the way out (or removing) the screw, will allow the cofee bean container to slide all the way out. However, when sliding it out, put a container under the edge of the machine housing to catch any residual beans and keep them from falling all over the floor. Here's how to do it: with the door open, look (or feel with your fingers) directly at the (closed) coffee bean container. Coming up from the bottom, all the way on the right side is the set screw. It's a black phillips screw that you can easily miss if you don't look carefully or use a flashlight as it blends in with the housing. Good luck.
