SOURCE: i carnt remove the turntable platter can anyone help
The platter needs a drop of oil as the platter and motor shaft is a machined fit, Via brass upside down v as the platter will be reversed ie: a A WITH NO LINE . You can place two plastic wedge shaped blocks ,one on each side of the platter with even pressure and work up.
SOURCE: Vestax pdx 2000 platter moves back and fourth
This is the most east turntable ever made. but are the two screws tied ?which keep the platter on it's place , if so unsrenew them and you see the four mounts where the motor is attached with the top deck , can you move the spindle , (where you screw to two screws in) and does the whole motor moves or only the spindle. Case one , unscrew the case and tighten the four screws, case two: bearings deed, buy a new motor.
