I have connected it via Keyboard wedge to my host, and it scans only first 7 digits of bar code. I have installed drivers also, and I have scanned bar code which is provided in support file in Chapter 5 Keyboard wedge interface. Does anyone know any solution?
SOURCE: I have a Symbol LS1203 but it doesn't read a C39
you would need to set the correct length for the barcode, there are several settings at the page 186 of the Product Manual located here http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=5880807apdf
The options are One Ddiscrete Length, Length Within a Range or Any Length. Please select one of them by scanning the approriate barcode.
SOURCE: scan bar code using motorola MC75
there are several ways to use the scanner: you can have an application directly with scanner drivers implemented. Or you can install the application DataWedge provided by the manufacturer.
The DataWedge application will activate the scanner and the decoded barcode is sent as usual keypad input to the system. The application is running in background, so you can have your favourite simple application in foreground and scan data directly.
To download the DataWedge application please go to support.symbol.com website and search for DataWedge, or use this direct link http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=12685
