I have tried F12, F8 and Del - to no avail
SOURCE: Acer Aspire T180 PC Desktop
Hi there, again no theres no beeps and its going no futher than the white ACER screen and ive tried the ribbon cable making sure its connected correctly. usually there should be a single beep before the post start-up? and the light on keyboard still not on! you dont think its a chip on the motherboard that the keyboard goes into? new motherboard perhaps!!
cheers again
SOURCE: Can't enter BIOS
I had this problem. Puzzled the hell out of me. Reading the posts above led me to believe it might be a problem with the USB keyboard. I changed the keyboard to a different USB port, and Bingo, I was in there!
SOURCE: windows keeps restarting. I can't
I have encountered this problem.my solution is this,
STEPS:
1.)Remove you HDD and place it to another Computer or PC.Then make it a slave drive or secondary drive.
2.)If your computer detect your HDDr,try to right on it and press Properties>Tools>Error Checking and press CHECK NOW.
3.)After that check the two check box and then press START. (if it says that you need to restart your computer,just restart it)
4.)Then when the scanning and repairing is done.put back you HDD on your desktop and it will work and boot properly.
