This oven has power, the conveyor works, but this unit has no heat what so ever, when you turn on the power switch the orange light comes on for a fraction of a second, then goes off still no heat is working ty in advance.
SOURCE: Hi, I have a Lincoln
Ignition Control:
The Ignition Control operates on both 24 VAC and 120 VAC. When the control is
energized by 24 VAC from the Transformer, 120 VAC is switched by the Ignition
Control to the Hot Surface Ignitor for 45 seconds for Hot Surface Ignitor warm up.
The Ignitor glows red, 24 VAC is switched to the gas valve which opens, and
ignition should now occur. If ignition does not occur in 6 seconds, the control will
lock out. To recycle after lockout, turn off the burner switch for 45 seconds and
then turn the switch back on.
Temp control:
When the Centrifigual Switch of the Burner Blower Motor closes, power is applied
to the Temperature Control. The 2.5K ohm Temperature Pot is adjusted to desired
temperature. The Thermocouple will provide varying millivolts to the Temperature
Controller. The Temperature Controller supplies 120 VAC to the Solenoid Valve at
intermittent intervals to maintain desired temperature.
This information link Lincoln/1116 pdf
This info was provided by: Partstown
I believe your problem is either going to be ignition lockout or a faulty thermocouple in the temp control circuit. Most likely the thermocouple. Hopefully the manual above will shed some light on your problem.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: Hi, my daughter has an impinger lincoln pizza
First you should check the ac source of the unit if their is a power try to use some device to confirm that there is an ac supply like charger or electric fan, if there is power to the source then you should check the fuse if not busted or if it using a breaker try to turn it of then turn it on it may be defective sometimes the contact of the breaker is not properly contacting to each other this hopping that this may help you. thank's
