try cleaning up the headset hole in the phone using a cue-tip for ears. dry . and if the headset icon doesn't disappear un-plug and re-plug the jack eventually power off / on restarting the phone. see if this helps ;) good luck!
You can't remove your proper, Now put your earphone and start the player, now you hear the music, and sound, now off your music play and plug out your earphone, now surely you get the sound.
Just make a jumper from the jack , on the ear peice point , one wire should be connected to ground and otherv one on the head phone jack , it will need some expert skilling
go to tools and setting --> sound settings --> keypad volume...see if you see "KEYPAD VOL-EARJACK"...that means that your phone is stuck in EARJACK mode....get a wired ear piece, plug it in, make a call, and then unplug after you end the call....that should resolve your problem...
i put it in the freezer, hit it, drove a nail into the earjack port. then i poured water into the earjack port, held a lighter to it, and blew into it, none of that worked, so i jammed a paper clip into the earport and that fixed it. i also slammed in on the ground a few times.
When the call has gone through, try changing the volume. If it says "Earpiece-Earjack Mode", the phone 'thinks' something is plugged into the data/charging port. Try using a clean toothbrush with a very small amount of alcohol on it (90% isopropyl is best) and brushing the port vigorously. If using 70% alcohol, use dust off or someother cnned air to dry he port out. If you are still having he issue, damaged is inside the phone and probably can't be fixed.
as it will be set on the ear phone mode or the internal speakers got malfunctioned.just remove the battery of the cell after turning it off .then insert after couple of minutes and check out.it many a times gets resetted.
