Question about SanDisk Sansa e250 MP3 Player
Slot radio cards
Does it play preloaded slot radio cards
2 Suggested Answers
SOURCE:
Mr_Wizardtex
  • 205 Answers
SOURCE: Sansa MP3 recognizes 8 gb micro sd card as a 4 gb card
your reader does not support the 8gb device, look for firmware upgrade for the reader
Posted on Jun 29, 2009
How to install saa7134
Open your CPU casing then install your pci capture card to one of your motherboard PCI slot you can Find it just read the slots of your motherboard they have a label on it some times PCI slot of a motherboard support multiple PCI slots just connect it on one of that slot..After installing install the installation software CD which is included in the package.
Jul 07, 2011 | Philips SAA7130 TV Tuner/FM Radio/Video...
What type of graphics card would I need to upgrade
Open the case.
Is there an add-on video-card, or is the video "integrated" onto the motherboard?
If not, then look at the "empty" slots for add-on cards.
The WHITE coloured slots will take a PCI (not PCI-Express) video-card.
If there is a BROWN slot that does *NOT* line-up with the ends of the WHITE slots, the slot will take an AGP video-card.
If there a DARK-coloured slot that *ALMOST* lines-up with the end of the WHITE slots, the slot will take a PCI-express video-card.
Mar 26, 2010 | Dell Dimension 1100 PC Desktop
How do i play gba games that are in slot 2, i push the ''slot 2'' button and it goes to config
they should work automatically when plugged in, take any card out of slot 1 which is the master slot and restart the ds with the gba game installed
Jan 16, 2010 | Nintendo DS Lite Console
I`d like to use the mp3 on my GPS but don`t know how to put music or pics on
You need a standard SD digital memory card (not the newer HC high capacity cards as Magellan does not guarantee compatibility although I did get one to work that was a micro SD card with the full SD adapter). You will need to put your mp3 music files from your PC onto the SD card just as you would your mp3 player; insert the SD card into an SD slot on your computer, laptop or USB adapter and copy the files to the card. After files are saved, put the card into the slot on the right side of the Maestro and then refer to the User Manual (http://www.magellangps.com/support/product.asp) page 64 to see how to play the music. You can play through radio speakers or by using headphones/ear buds with a USB connector.
Oct 11, 2009 | Magellan Maestro 4350 GPS Receiver
Burned RAM
just remove the 256mb ram it is the main problem only insert equal memmory of rams in 2 slots, if u insert 1gb ram in one slot try to insert also 1gb ram in other slot, donot inser 2 unequal rams in one time
Sep 28, 2009 | Computers & Internet
Purchased sd card with eurpope maps for my nuvi 205 that is preloaded for north america. how do I use it?
Put the card in the slot. Go to setup and select the map. If you're outside Europe, the screen will be blank (GPS fix is outside the map area).
Jul 29, 2009 | GPS
I want to play an high graphic games on my computer Which is Intel D865GVHZ and do not have avg slot on it can I play the high graphics on PCI graphic card
In today's generation the PCI Express Slot are used for graphic card and it is available in many motherboards.
It is faster than the AGP Slot and PCI Slot.
In your machine, if you want to play higher games than you use that AGP slot because it is faster than the normal PCI Slot.
To play higher games you need an at least 2 GB of RAM.
My suggestion is that you just upgrade your system with latest motherboard and PCI Express Graphic Card that will play your all games very smoothly.
Mar 09, 2009 | Intel D865GVHZ Motherboard
Cant get an SD card to play music
Some devices have a maximum 2 GB SD-Card size limit; do these cards you use exceed that size?
Nov 27, 2008 | Garmin Nuvi 660 GPS Receiver
Ps2 memory card
Hi Lofatman,
If this problem happens with the memory card when its in either slot 1 or slot 2
I suggest you clean the contacts of the memory card.
If it just happens when you have in Slot 1 or Slot 2 only,
 Go to Radio Shack and get a Can of contact cleaner that has a Brush built into the Spray nozzle.
  1. Turn off the PS2 and disconnect the power cord.
  2. Use a small screwdriver to press open the memory card slot. Do not use too much force, its delicate.
  3. Push the Brush sprayer up into the memorycard slot and spray a little and brush away at the memory slot contacts.
if you do not have success with that, you must open the PS2 case, and Remove the Controler ports and clean up the whole controller port assembly.
If that doesn't work, and your frustrated and not Electronically skilled enough to do this.  I can get the PS2 in tip top shape, for $32 and that includes return shipping.  I run the website www.playstationclinic.com
This should put you in business.
Oct 17, 2007 | Sony PlayStation 2 (PS2) Console
SanDisk Sansa e250 MP3 Player Logo
62 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Gyula Lacz
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
