Door pops open when the other door is closed. Is there a repair for this problem?
SOURCE: Side by side GE profile freezer door pops open
It almost sounds as if the magnetic gaskets aren't as they should be.
Most all combination units have a path between the two parts of them to allow circulation of air, the amount or rato of which, is controlled by an adjustment that really just makes a duct larger or smaller so temperatures can be balanced to fall within the range needed by each.
Check to see if, when closed slowly, the gasket surfaces are parallel to the steel of the housing.
If not, there is normally a little adjustment possible at the hinge mountings.
SOURCE: freezer door wont seal and stay closed
Your pushing air from the fridge part over to the freezer door when you clos it,the only thing i can suggest is make sure that the seal (which is magnetic) is clean and not falling apart,inspect it all around the door,and when closing the door i would close it gently.
Hope this helped.Let me know by rating me or
for more help go to live chat.Thanks
Len West
SOURCE: refrigerator door pops open, frigidaire top
The refrigerator needs to be perfectly leveled side to side dn should pitch back slightly. Also look at the plane of the doors, that is to say that they should be squared to the cabinet. If they are sagging, you may need to adjust the hinges.
SOURCE: freezer door pops open when fridge door is closed.
well u need to check the rubber of ur freezer ;s door .some damaging in the rubber is causing the problem.
SOURCE: French door refrig..right door pops open when left door is closed
remove the door and check the closer inside the door @ the bottom . it is a cam that helps close the door and it is probably broken part # 67002732. this was the problem with my maytag fridge-- 3 visits from A& E could not solve the problem. hope this helps
