Select Jazzy Used Electric Wheelchair Logo
j
jack daly Posted on Jul 25, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a hp8204b charger. power light comes on, fan runs 1-2 seconds then quits. does this charger need replacement?
Scooter Doctor
Level 3:
Master:
  • Select Master 401 Answers
  • Posted on Apr 30, 2016
Scooter Doctor
Select Master
Level 3:
Master:
Answers
401
Questions
0
Helped
122553
Points
1542
This charger is suspect I would take it to your local battery outlet and have them check it. I would not trust this charger!
Strege Mobility
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_bcbb89783b08c489
Charger not working fan not stay on and yellow light
You have the 4-amp charger version. If you have the U1 batteries on your Pride you can replace the charger with a 3-amp version after you have your batteries load tested and tested for internal resistance. Verify batteries are good and "finishing voltage" after charging is proper. (14.4volts per battery)
My hp compaq nc600 laptop wont turn on just an ornage light comes on, black screen and fan for 10 seconds then dies?
In the first instance you need to check your power lead. Exchange it for another one that you know works.
1helpful
2answers
I have a HP8204B Pride battery charger 24vdc 5a 230vac, the wire to the end connector (3 pin with 2 of the pins bridged) has come away and i don't know which wire (one black, one red) to solder to which...
The red wire is positive and is soldered to pin 1. You can see the 1 on the pin (non solder side) of the plug housing or on the solder side as a raised stamp 1.
The black wire is soldered to the negative pin 2. Two of the pins are bridged to inhibit the power chair operation when the charger is plugged in. Hope this helps.
THE ON BOARD BATTERY CHARGER ON MY HS1000 CTM POWER CHAIR IS NOT WORKING. WHERE CAN I FIND THE CHARGER I NEED HP8204B
Hello, This is CTM Tech Dep. Call me direct at 866-466-8168 or 909-590-1388 ex: 115 or email me at [email protected]. I will provide you with local dealers and low prices on 1. On board chargers or 2. Off board charger that are an option for your unit.
Thanks.
2answers
Laptop only turns on every now and then, charger pluged in but charger light not on, when trying to turn on fan kicks in, charger light flashes, then nothing, please help?
It sounds like you have a bad charger cord. Does it do the same when powered off the battery? Like it is tryin to start up. An d also make sure battery is plugged in good to the laptop,
2answers
Laptop fan spin for 2 second and display not show
You must veryfi the CPU and try without battery or try it without charger with a already charged battery! This must work!
1helpful
Computer won't start up and has a constant tone.
If the noise is constant then it means the problem is either:
1: a Power supply issue
2: a motherboard issue
3: a keyboard problem
the latter of the three being the easiest to fix, try booting with your keyboard unplugged or even better if you have another keyboard try using it to see if that corrects the problem.
If the above does not work then you have a problem with 1 or 2, and in order to find out for certain you will need to test it, you can goto your local computer diagnostic store to see if they can check which it is.
and hope its not a problem with the motherboard.
Hope this helps, and Good Luck
2answers
Dell D600 latitude will not power up
you can try to replace the motherboard, which is apparently totally UnHappy
Top Select Health & Beauty Experts
Rob Hill
Rob Hill
ADMIN Andrew
ADMIN Andrew
Are you a Select Health and Beauty Expert? Answer questions, earn points and help others
