Any digital camera records the date and time each picture is taken, storing this information somewhere in the JPG file, so you can stamp photos after uploading them on a PC. You can use Time To Photo software for example. It can stamp photos automatically in a batch.
The date display option can come from your camera or the software programme you use to view. Start with the software and disable the date & time display function. If this doesn't work then go into the camera menu and in the display setting change the date & time to either disable or none.
If you're talking about the arrow on the screen when viewing the picture, it is the AF indicator and does not show up anywhere else...PC, Photo prints etc. You can disable the AF arrow in the menu.
check t he camera settings and it should have an option for date and time which you can disable. Other people like to have the date to keep track on when the pictures were taken. hope this helps
problem is in memory card...i think. try with cleaning memory card contacts. use pure alcohol and small piece of cotton to clean dust or other dirt. if this not help, try some card reader to transfer images from camera to PC. try also with some other camera. it's possible memory card is damaged and you can't do nothing. try reinstall nikon software on your PC.
i think u have turned on the optic view finder mode. so the camera switch off the LCD so go to menu and search for the option to enable the LCD or to disable the optic viewfinder ok.
The EOS Digital Rebel, EOS Digital Rebel XT and EOS Digital Rebel XTi do not support stamping the date and time on the image.
It is not possible to record the date and time as part of the image at
the time the picture is taken. However, the date and time is captured
in the EXIF information of the image at the point of capture. It is
possible to print the image with the date and time via printing
software. Please see the documentation for the software package that
you use for printing images for the proper procedure.
To copy pictures from memory to your memory card turn your camera on and press the button above the menu button. This will start showing the pictures already on your memory card. Next, press menu and the down arrow. This down arrow is located on the round button with the "OK" in the center. Your choices should be DELETE, SLIDE SHOW, PROTECT, QUALITY CHANGE, RESIZE, and the one that you want,COPY TO CARD. Press OK and the camera will copy pictures from internal memory to the memory card. This information is on page EN-62 and EN-63. I know that this works because I was testing the information as I was typing it!
