I have a new N300 range extender cab i connect to my linksys wrt54 G router
How to use remot for videocon FST 21 tv
Are you facing issues while doing the Linksys extender setup? there are troubleshooting tips from the table of experts to help you make the most of your Linksys WiFi device.
WRT-54G is outdated and obsolete. It is also prone to being hacked.
SOURCE: Cannot connect to WRT54g
think you have to connect a cable to the ethernet adapter of your desktop in order for you to connect to the wrt54g. uless you have a wireless lan on your desktop. also check your channels. and manually config your router through 192.168.1.1.......
SOURCE: Need to add Linksys WRT54G-TM wireless router with Linksys SPA 2102 phone adapter
your SPA2102-R seems to have one ethernet connection and one internet connection.
your WRT54G-TM seems to have one internet connection and 4 ethernet connections.
What you are trying to achive is; plug a ethernet cable into the ethernet connection on your SPA2102-R then plug the other end into the internet port of the WRT54G-TM
hope this helps, I have assumed that you intend to use a DSL broadband supplier not ADSL.
if you are changing service from DSL to ADSL then your WRT54G-TM needs to be first in line configured and working. then plug the internet port from the SPA2102-R into any of the WRT54G-TM ethernet ports.
SOURCE: Linksys WRT54G wireless router not compatible with Aztech modem?
Darvin, gotta love your ISP. Never fear......
if it isn't too much of a problem (knowing you have wireless setup done already), then do a factory reset on your router ** remember to copy the WEP Key if you have, or recall the PASS PHRASE so you won't have to reset all wireless devices ** Reset is located on back, you need a ball point pen to reach the reset switch.
Reset process: unplug, take ballpoint pen & insert into reset switch & plug unit back in. Sometimes tricky, but you should notice green light goes to yellow/orange upon resetting.
RESET or NOT - you want the Linksys set for ::
Connection Type - AUTOMATIC (for automatic discovery)
Router IP Address - 192.168.2.1
DCHP - ON, Addresses - 192.168.2.100 and allow 5-50 users
(for security, assign the number of DESKTOP + WIRELESS expected users +1, this way you don't get overrun without knowlege)
Take the cable from Aztech ETHERNET OUT to WAN on Linksys. (usually BLUE) (??) not 100% sure as I have the little silver pocket edition of the same Router. - power cycle (turn both DSL modem & Linksys off for 20 seconds. turn on DSL Modem, wait till it's about as ready as possible, turn on Linksys, should only take 20-30 seconds to power up & recognize.
VERIFY SETTINGS: access router - 192.168.2.1, goto STATUS. you should see IP Addressing, SubNet, DNS1 & DNS2 settings. If you do not, then you have no internet connection.
ALTERNATIVE,
Setup Linksys Router with COnnection Type: PPoE, you will need your ISP assigned ID & Password. Follow all other instructions properly.
If you still have problems, please contact me at 906-495-1707 or via Yahoo IM [email protected] or through this website.
once
SOURCE: Intermittent/non-existant connection with LinkSys WRT54G router
I would get a Range Expander... it sounds like you are having problems recieving a constant signal. When you do get the range expander plug the Range Expander halfway between you upstairs computers and your downstairs where your router is at. I hope this helps!!
Sincerely,
cdixon18
The ManInsideTheMachine
SOURCE: Linksys WRT54 GC failed auto port forwarding
check in your pana sonic ipadreses then test in your network can you able ping of ip of cam?
If you can get ping and if you save ip forwarding port 80 to cam ip then check in camera that the settings of "access via interent is enabled" then you cana cces it with cam ip with 80 http port.
To know the simple and quick steps for Linksys extender setup you can contact us.
that wrt54 is the worst router ever made, it gets the junk award. 10/10 rated bad.
https://www.cvedetails.com/vulnerability...
read that and stop using this very bad router.
ask now to do it correctly first and hardware and size of home are first.
wifi loves to fail
to avoid some of this fact, we learn to do a lay out of the home (and all floors)
wifi has a very short range (unlike 5G) it can fail at 25ft if walls are dense !!!
50ft is par, but is slow at that range.
we make a floor plan then create wifi zones
with reasonable ranges not 50ft.
the put and AP in each zone centered.
all AP are wired from far to near main router.
we use only Cat6 ethernet wire from AP to AP then to main router.
this is how your local collage is wired. wifi.
first have a plan. the buy hardware, then set it up, in THIS ORDER, not yours.
try to avoid 8 million hits other doing this wrong seen here.
https://bfy.tw/S4By
