Karcher WV50 Window Vacuum Logo
A
Anonymous Posted on Jul 24, 2014
My karcher window vac does not seem to charge?
Making a strange noise and no power even after being fully charged.
Les Jones
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Sep 08, 2014
Les Jones
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
9985
Points
My window vac was not always charging. Moving the plug that fits into the charging socket seemed to make it work so I suspected a bad connection. Removed cover and found that black wire had become unsoldered from charging socket. Also found that the pins in the socket only passed through the solder tags. Soldered the tags to the pins. NOTE the pins will push out of the back of the socket so the soldering can be done without melting the plastic. MAKE SURE YOU DO NOT REVERSE THE POSITION OF THE PINS IN THE SOCKET.
john
Level 1:
New Friend:
Problem Solver:
  • Contributor 4 Answers
  • Posted on Jul 25, 2014
john
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
Questions
0
Helped
14218
Points
Have you tried to take it all apart just a small bit of rubbish will stop it from working.
Hi, 1. The machine stops after a few minutes, even though supposedly fully charged @. Difference between an Animal and a V6 cordless
Dyson will replace the unit for free. Call customer service # on the vac with the serial number
No suction on my Karcher window wv2 vac
Check the hoses for clogs due carpet fibers.
2helpful
Karcher wv50 spare on off switch
If you contact one of the Karcher Centers ( details are on Karcher.co.uk website) they may be able to help.
regards Gary
2helpful
2answers
Why wont my karcher window vac switch on even after a full charge any ideas ?
Take it apart and see what is stopping it (the motor) from turning .
9helpful
Can't switch Karcher window vac off
I had the same problem and I let the battery run down to stop it cycling on and off. My husband investigated it and found that there is a fault with the on board battery charge sensing circuit. (when the charge is about 10 to 15 % remaining the onboard ic controller cycles the unit on and off, irrespective of the switch. He checked it by cutting wires to the switch and it still cycled off and on so the switch was not faulty.
He put it all back together and said to charge it before it gets too low. If it cycles on and off it probably needs a re charge at that point.
Unfortunately there is no battery level indicator on the tool and nothing to suggest in the manual of what may happen when battery is flattening.
I am taking this up with Karcher as I only used it three times so far and it it was not a cheap gadget. Hope this helps
1helpful
Hoover Freejet Cyclonic will not charge after battery run flat
basically, the batterie pack is shot and it will cost about £40.00 ish to replace. as you said, a right rip off
Dec 24, 2008 • Vacuums
Top Karcher Vacuums Experts
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
Are you a Karcher Vacuum Expert? Answer questions, earn points and help others
