Starter spins but does no engage, rap on starter and it will then start but when turned off it just spins again until the starter is tapped with tool.
SOURCE: I have a Toro Zero Turn mower that won't start. I
two things possible you have a sticking float or if its old enogh the electrical ign system is going to have to be replace cheap and easy if the model is old enough this electrical ign takes the place of points and works the same
SOURCE: starts and runs great(when engine is
I would check the gas cap. If the gas cap is plugged or pieces missing from inside it will not allow air into the tank and the fuel will not flow properly to the carburetor. Just loosen the cap and try it, if it does not change check for dirt in the fuel line.
SOURCE: problem with Toro self starter
remove the cover and look for a missing tooth on one of the gears
check for spark is the wire on the spark plug is the plug good check for fuel flow possible electrical short
