There are three items that are connected together needed to create spark on your 1997 Honda 4-wheeler, regardless of which model it is.
Before we go through a checklist of these three important parts, look for a black wire with a white stripe that runs to the ignition switch and kill button from the CDI box. Disconnect this wire before it gets to the ignition switch and kill button, then check for spark. The most likely cause is a broken kill switch on the handlebar, or shorted ignition switch. Such a condition grounds this wire and kills the spark.
If this test did not restore the spark, continue reading...
Here is what is required to create a spark.
First, the alternator has one coil which generates a high voltage--about 125 Volts AC for the CDI ignitor box.
Second, there is a pulse voltage generated once every revolution of the engine that goes to the CDI box. This pulse causes the CDI to dump its stored energy from the 125 volt line into the primary of the ignition coil.
Third, If the two connections of the wire that runs from the CDI to the Coil are BOTH SHINY clean, the ignition coil will generate a spark.
If any one of these 3 don't happen, the spark will go away. Of these three, item 3 -- one or two tarnished and/or dirty connectors -- is the most likely cause. Just an added resistance of 0.3 Ohms or more in the CDI to Coil connections will cause the ignition to fail. No other wires have to be this clean.
Hi Steve.You will need to get under the starter pully and rub the spark generator with some glass paper and WD40. No doubt the generator has gone a bit rusty due to the water.The fly wheel will need cleaning to. Also give it a warm place to stay for a few days to completely dry it out. This should be ok then. John
The spark generator that sits close to the fly wheel only needs a mm gap. Make sure that this is the case. If there is a small gap there is possibly a break in the wire or the points under the fly wheel may also be rusty.
