Moved it to start heater in spring but now cannot budge from 'on' position to 'pilot' to relight pilot--not sure whether to take off casing of know which is held on by 2 screws to check?
Thanks Wiz!, but I push down hard to get it to turn and it wont budge at all--should I take 2screw casing off? thanks much!Thanks Wiz!, but I push down hard to get it to turn and it wont budge at all--should I take 2screw casing off?
thanks much!
You can't post conmments that contain an email address.
Every boiler will have manufacturer lighting instructions on the unit, so be sure to read it thoroughly and turn off the gas for 5 min to make sure there is no gas build-up around the boiler. Some have electronic ignition and some require a manual lighting of the pilot. If the control knob has only ON-OFF, it has electronic ignition. Simply turn off the power (at the electric switch on the boiler or at the breaker box) and then turn it back on and it will relight itself when heat is needed) If it has ON-OFF-PILOT, you will have to light it manually. You will have to turn the gas valve knob so the arrow is pointing at the word "pilot" and depress the knob, while lighting the pilot with a lighter or match. Continue to hold the knob down after the pilot is lit for about 30-45 seconds to allow the thermocouple to heat up. If you release the pilot knob and the pilot stays lit, you can turn the knob to the "ON" position and the burner will light. Please be careful. if you are not sure what you are doing, call a professional.
Jennifer, the instructions posted by Rheems on the heater are wrong. You must first rotate the dial clockwise, use force (in our our case) to get the pilot to its position. The folks at Rheems are nuts not to check their instructions before printing them and plastering them on their hot water tanks. Disgraceful, period.
First, is the PILOT burning? If so, is the heater Control Knob turned from PILOT to the ON position? If you have any other gas appliances in the home are they working? If they're not, your gas has been turned off. Contact your gas provider.
If the other gas appliances are working and you answered No to the first two questions, you will need to relight the pilot. After the pilot lights and holds for 1 minute, turn the Control Knob to the ON Position. Turn the thermostat up and the burner(s) should light.
The main control knob will have a "Pilot" position. Set it there, then light the pilot. You may have to press and hold the control knob to do that. There may be a striker button that will relight the pilot while you're holding the control knob or you may need to use a match or a candle lighter.
Once the pilot is on for 30 seconds or so, it will remain lit when you release pressure on the control knob.
Move the gas valve knob to the PILOT position and press down on the knob. You will be pressing down on a spring loaded safety magnet. Now light the pilot and keep holding down the knob till the thermocouple gets hot enough to produce electrical current and hold that spring loaded magnet in. This is your safety device. If the heat gets too hot the furnace has a fuse in line with that magnet. When the pilot stays lit by itself without you having to hold down the button then advance the knob to the ON position. Then go to the wall thermostat and turn on the heater.
Open the lower panel. You will see a valve with a knob marked On Pilot and Off. This is the gas valve. Turn the knob to Pilot. Push in on the knob and if you are in the correct setting, the knob will depress about 1/2" into the valve. Now look for a red button and snap it in much like a gas grill starter. Keep the knob depressed and look into the small viewing port to see if you started the pilot. Hold the knob for 30 seconds then let it out. You should see a blue flame. If you don't , try it again and hold the knob in longer this time. Once you get the pilot to lite, rotate the knob to the On position. If for some reason you can't get the pilot to stay on, you may need to replace the thermocouple. If the pilot won't light at all, you may need to get into the pilot Assembly with a long match or grill lighter and light the pilot.
You pilot ignator is plugged.I take a small wire and run it in the hole every year and I also Blow the heaters out real well with air.THis has always worked far me.I need a phone number or email address to Pro Com because i'm having problems with a new one i just bought and I can't find the papework.Could you pleas eif you have this info email it to me
Good Luck
Jay [email protected]
thanks much!
