Kodak EASYSHARE 5300 All-In-One InkJet Printer Logo
Posted on Jul 24, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Scanner is making a grinding noise and won't scan.
Steve Nordquist
Level 3:
  • Master 982 Answers
  • Posted on Aug 04, 2014
Steve Nordquist
Master
Level 3:
Answers
982
Questions
Helped
213400
Points
2276
Did I mention it sounds like the scanning assembly is locked in place for travel and needs unlocking?
Brother MFC scanner bar is stuck
check the continuty in scanner cable to cis unit and check the continuity 2ends off scanner cable.
1.cable problem
2cis problem
Grinding noise in copy mode?
The Grinding Noise has something to do with the scanner not the Printing Part, I think the scanner could have something stuck on the moving tray....!!!!!!
1helpful
2answers
The scanner works but makes a grinding noise that is getting worse
Normally Canon scanners work well for long time, Change the pickup rollers for every 250,000 pages and check other rollers for every 500,000 pages. In case you have been scanning documents with quite a good amount of dust, you may need to check at an earlier interval. Replace any worn out roller. Check if the small bearings at the end of each roller is perfect. Clean thoroughly all the rollers, dont use solvents. S. Mohan, Chenna, India
2helpful
Grinding Noise in my scanner
Try cleaning the guide bar that the scanning head rides on, apply a thin film of lithium grease on the guide bar
Grinding noise
The most common problem is that the pulley breaks, you might be able to see it through the glass. looks where the belt goes, and see if the pulley is broken.
also, some people forget to unlock the locking mechanism when the unit gets moved, the locking switch is on the side.
Scanner making grinding noise
Please open and apply oil on roller rod as some rust have accumulated on it prohibiting it move.
3helpful
2answers
Makes grinding noises, refuses to scan; WinXP
take a look on the underside of the scanner. there may be a switch that goes from lock to unlock. try to move it to lock and back into unlock. this lock is usually used to lock the bar from moving during shipping. if this got moved back to lock or bumped while you had it turned over, the scanner will not allow the bar to move.. try this first.
Top Kodak Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
