Odometer
The IPC contains a season odometer and a trip odometer. Momentarily press the trip/reset switch on the IPC in order to toggle between the season odometer and the trip odometer. Press the trip/reset switch for greater than 2 seconds, while the trip odometer is displayed, in order to reset the trip odometer. The IPC displays the vehicle mileage and trip mileage as determined by the BCM. The BCM calculates the mileage based on the vehicle speed signal circuit from the PCM. The odometer will display 'error' if an internal IPC memory failure is detected or there is a loss of class 2 communication.
IPC - instrument panel cluster.
Replace the instrument panel cluster (IPC). Refer to Instrument Cluster Replacement .
Odometer
The instrument panel cluster (IPC) displays a season odometer and a trip odometer. Momentarily press the trip/reset switch in order to toggle between the season odometer and the trip odometer. Press the trip/reset switch for greater than 2 seconds, while the trip odometer is displayed, in order to reset the trip odometer. The odometer is calculated and stored electronically in the body control module (BCM). The BCM uses the vehicle speed information from the engine control module (ECM) to calculate the odometer. The odometer displays 'error' if an internal IPC memory failure is detected. The IPC stores a backup copy of the odometer value incase the IPC stops receiving a valid odometer value from the BCM. The odometer will display 'error' if an internal IPC memory failure is detected.
Your best bet , take it to a qualified repair shop .
The IPC calculates the mileage based on the vehicle speed signal circuit from the PCM. The odometer will display ERROR if an internal IPC memory failure is detected.
Discussion mode will work if your 8000 unit created the bridge call (that is called all other VC units). I think by default the software will allow a bridge call of up to 4 sessions (yourself is included). Also check to see what mode the other VC units are set to.
Error Code 291 is an internal hardware failure. There is no service fix for the field technician; the unit must be removed and sent back to Polycom for repair.
The IPC displays the season odometer information from the BCM in the driver information center (DIC). The odometer will display an error if the IPC detects invalid odometer data from the BCM.
You'll need to find a 10 AMP fuse in the instrument panel cluster, follow this diagram t locate it: https://ricksfreeautorepairadvice.com/2003-chevrolet-silverado-fuse-diagram/
This means the phone's SIP application has been erased. You will need to download the SIP app and BootROM from the Polycom support page, host the files on a boot server, and then point the phone to this server from the server menu so the phone will reboot and download the files.
