Maytag Atlantis MAV6451 Top Load Washer Logo
A
Anonymous Posted on Jul 24, 2014
Washer will drain & fill at the same time
Washer will fill and drain water at the same time.
  • ketchus2004 Feb 11, 2021
    I just bought the machine today. I was doing so research online and it seems I need a extension on the drain hose
First Service
Level 2:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 181 Answers
  • Posted on Jul 24, 2014
First Service
Expert
Level 2:
Cheetah:
Answers
181
Questions
Helped
49173
Points
482
Sounds like your timer is bad.
4 Related Answers
Anonymous
  • 1543 Answers
  • Posted on May 26, 2009
SOURCE: washer will not fill up with water...runs right back out of drain tube
Make sure the drain pipe is at least 34 inches above to bottom of the washer and that it is not sealed at that point. This will prevent siphoning.
mwarej123
  • 454 Answers
  • Posted on Jun 25, 2009
SOURCE: washer is filled with water,,it wont drain,,nor
Sounds like a bad lid switch. When you close the top lid, there is a safety switch that closes, it is actuated by a pin attached to the lid, there will be a small hole located on top of the machine, somewhere on the perimter of the top of the tub. Could also be a bad timer.
Anonymous
  • 162 Answers
  • Posted on Jan 18, 2010
SOURCE: washer fills with water, but before it begins to
drain hose is siphoning. pull most of it out of the drain and secure with tie strap.
Anonymous
  • Posted on May 03, 2013
SOURCE: Maytag Atlantis MAV6200AWW Washer Problem?
I HAVE AN ATLANTIS MAYTAG WASHER . I HAD THE SAME PROBLEM AND I SOLVED AS FOLOLWS. REMOVED THE MOTOR, I APPLIED GENERAL PURPOSE GREASE ON BOTH SIDES OF THE SLIDING MOTOR SURFACE PLATE (MOTOR BASE) . THE GRASE HELPS THE MOTOR TO SLIDE BECAUSE AS YOU KNOW THE MOTOR DOES NOT HAVE ANY ADJUSTMENT. TRY IT PLEASE . GOOD LUCK
Why does washer sometimes fills with water continuously / yet never fills up?
Many laundry machine hoses require a physical air gap, or air break, between end of hose & standpipe drain. This prevents both siphoning & sewer water backup entering washing machine... ( UPC ill. Manual for picture) ... Buzz*
6helpful
2answers
WHAT DOES IT MEAN WHEN MY WASHER STOP STOPS & SHOWS LF OR F1? i CAN'T READ IT!
The LF error means Long Fill.
When you start a cycle the water should come into the dispensers. If you have a good flow through the dispenser the valves will be okay.
I recommend checking the inlet water screens on the back of the washer. The inlet screens are located on the water valve. To access the screens you will turn the water off and remove the inlet hoses. The screens prevent debris from entering the valve and sometimes over time mineral deposits build up on the screens. This can block the water or slow the water fills down to a trickle. You can pull the screens out and clean them if necessary. Flush the inlets thoroughly with water when replacing the screens. If debris gets past the screens, it can cause the valves to stick open and an overflow of water can result.
While you have the fill hoses disconnected, place the ends of the hoses in a bucket and briefly turn on the faucets to check for proper water pressure and flow from both hoses.
A common reason for an L F (long fill) error on this washer is the drain hose being stuck to far down the drain standpipe.
If the drain hose is to far down the standpipe then a siphon can occur which causes the washer to fill and drain at the same time. This will cause a long fill error.
Water runs continuously tub never fills My Fisher & Paykel top loader keeps filling and draining at the same time. It never gets full of water. The hose is way higher than the machine, but still drains...
where is water draining into? have u got grey water hose attached to it?make sure u can see end of drain hose, put into bucket at lid level, if it still drains as it fills u have a faulty control module.please reply for more help
I have a Kenmore N2. What would make my front load washer fill back up with some water after the drain and spin cycle is complete?? IF I let the washer go until it's done and go downstairs to take out,...
first, run a rinse,drain & spin cycle. after it finishes filling, shut the water supply (taps) off. If water enters the washer after the drain, it has to be sifoning back in from the DRAIN hose. Check to see if the drain hose is not going up above the washer more than a few inches
1helpful
Drain while filling
You will find your drain pipe is to low. Raise it to the same height as the machine retry.
8helpful
2answers
Kenmore Elite Calypso Washer fills then doesn't advance..
You can get a replacement pump at pcappliancerepair.com - part # 285990 - and a lifetime replacement warranty on the pump - for (at this time, July 2009) about $124 total.
However, before you do anything you can run the washer diagnostics by pressing the following key sequence to put the washer into the Automatic Service Diagnostic mode (make sure the washer is EMPTY of clothing when you do this):
Prewash Options --> Wash time --> Prewash Options --> Wash Time (also known as a "Key Dance"). You have to press the 4 keys within 5 seconds for the washer to enter the diagnostic mode.
The washer will start counting down from 99 on the LED display and will run through the following steps:
Display 99-81, Nutate & Fill (washer plate rocking motion is called Nutate), Cold Water, Drive Motor Speed 300
Display 80-61, Nutate & Recirculate, Cold Water, Fabric Softener Dispenser, Pump in Recirculate mode (wash), Drive Motor Speed 275
Display 60-41, Nutate, Fill & Drain, Hot and Cold water, Bleach Dispenser, Pump in Drain Mode - LISTEN FOR IT TO RUN, Drive Motor Speed 250
Display 40-21, Nutate, Fill & Drain, Hot Water, Detergent Dispenser, Pump in Drain Mode, Drive Motor Speed 225
Display 20-01, Spin & Drain, no water fill, no dispenser solenoids, Pump in Drain Mode, Drive Motor Spin Speed 500
Return to Standby at the end of the countdown.
You can press Cancel at any time.
Also, if you can get the washer drained, when you tip it on its side and open the bottom cover (unplug the AC power first and secure the water lines & drain), if you shine a bright flashlight up inside the outer case of the washer, look for a plastic sleeve with some paperwork in it.
If it is there, you will find the washer's Service Diagnostic Paperwork, a large fold-out sheet that shows all the keystrokes, like those documented above, for putting the washer through a bunch of diagnostics.
2answers
Water leak
I WISH I COULD HELP YA. LET ME TAKE A SHOT AT THIS: IT SOUNDS LIKE A HOSE IS LEAKING ON YOUR WASHER. HOW OLD IS YOUR WASHER?
RODNEY
Keeps filling with water, but draining at the same time!
be sure your drain is nearly to the top of the washer if it is you may need to try a siphon break
Top Maytag Washing Machines Experts
ZJ Limited
ZJ Limited
john h
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
