Dell 1135n AllInOne Laser Printer Logo
A
Anonymous Posted on Jul 23, 2014
How to replace fuser in Dell 1135N printer
How do you change the fuser
ADMIN Andrew
Level 3:
Top Expert:
  • Dell Master 66,947 Answers
  • Posted on Apr 05, 2022
ADMIN Andrew
Dell Master
Level 3:
Top Expert:
Answers
66947
Questions
Helped
5082436
Points
379689
Replacing The Main Service Part Of Fuser Unit - Dell 1135N ...
https://www.manualslib.com > ... > Service manual
Dell 1135N Manual Online: Replacing The Main Service Part Of Fuser Unit. 3.6.3.1 Spring-Es Separate it as take up the circle-area of Spring-Es from hook.
How to replace fuser in Dell 1135N printer - Fixya
https://www.fixya.com > support > t24863785-replace_...
Jul 23, 2014 - how to replace fuser in Dell 1135N printer how do you change the fuser - Dell 1135n AllInOne Laser Printer question.
20 Most Recent Dell 1135n AllInOne Laser Printer Questions ...
Nov 18, 2012
While install refil toner in Laser printer Dell 1135n - Fixya
Nov 19, 2019
My 1135n all in one won't recognize my local computer - Fixya
Nov 18, 2019
Dell 1130 Laser Printer 1130 fuser error #02-000 - Fixya
Aug 22, 2012
More results from www.fixya.com
Support for Dell 1135n Multifunction Mono Laser Printer
https://www.dell.com > Support > Product Support
Search Dell 1135n Multifunction Mono Laser Printer Support Information ... Troubleshoot Printer Spooler Errors, and Removing Printers from Windows Registry.
Replacing the fuser on Dell Laser printers (C2660dn ...
https://www.youtube.com > watch
PREVIEW
1:04 Watch this video to learn how to replace the fuser in your Dell C2660dn, C2665dnf, C3760n/dn and C3765dnf laser printer.
YouTube · Dell Support · Aug 15, 2014
Scanning with Dell 1130
Which Dell 113x do you have? There are the Dell 1130 and Dell 1130n Monochrome laser printers that do not have a scanning unit. See https://www.dell.com/support/home/us/en/04/product-support/product/dell-1130/docs . If you have these, you can't scan. If you have an all-in-one, perhaps the Dell 1135n multi-function laser printer, https://www.dell.com/support/home/us/en/04/product-support/product/dell-1135n/docs , see below. Dell also lists a B1163 multi-function printer. See Dell support for the printer list of US printers: https://www.dell.com/support/home/us/en/04/products/electronics_accessories/electronics_accessories_printers?app=products&~ck=mn .
In general, for multi-function printers, the unit must be in a ready to print state. (Out of ink messages will stop the unit from scanning.) Next the full software package should be installed before connecting the USB cable, if that is used. If the OS finds the drivers, you may only get the printer drivers.
Next two-way communication must be allowed. For a USB cable, don't use a cable longer than 6' and replace it if there is a communication error. For a network connection, make sure that the firewall is set up to allow the communication. Finally, try to launch a scan from the computer, using the software that is part of the full package. You will need to have a scanning monitor launched during boot to look for button presses on the scanner. This monitoring software requires some setup before it correctly responds to the button presses. For Windows, this is the Dell Scan and Fax Manager (on the 1135n). You need to enter the Properties section for the printer. Then go to the Set Scan Button tab and use the Available Applications list to move the desired applications to the Front Panel Scan Destination. You should also set the file type here. In the Scan Property section, set the default destination for scanned images, the standard resolution, and other items. Also make sure to set the type of connect in the Change Port tab. For the documentation on the scanner for the 1135n, see page 47 on at https://downloads.dell.com/manuals/all-products/esuprt_printers_main/esuprt_printers_mono_laser/dell-1135n_user%27s%20guide_en-us.pdf .
I hope this helps. Please add a comment if you have a different all-in-one printer.
I am trying to print, when the paper comes thru it get stuck under the roller and the metal. What can I do?
first you should check the fuser filme or pressure roler is good or not same time if fuser filme is cut it will happend....
On my dell 1135n the scanner says not connecting, have unplugged the power and the usb port cables but have not fixed the issue
It could be the network connection or PC that your printer is plugged into. Try swapping it with another printer that you know works. If it still fails, you have isolated the problem to the printer itself.
Dell 1135 door open error
Why The Dell Printer Offline Error Occurs?
§There can be issues with Printers and Devices in the control panel thereby leading to the problem at hand.
§There can be issues with the Printer Settings resulting in the particular error.
§Issues with the Printer Driver can also cause this Dell-related error code.
§There can be some connectivity issues with your Router or Modem that are probable causes of the Printer Offline error code.
For more info Do Visit Us: Dell Printer Offline
1helpful
How do i scan to pc on network with Dell 1135N
Have you ensured that the printer is attached to your wireless LAN - very often it is worth trying to disconnect it and reconnect using the proper password etc.
Dell 1135n not compatible catridge
If you look at the face of the cartridges and cound the pin connections you will see that they are different.
Dell 1135n driver
Go to dell.com input your model number then go to drivers and support section look for that driver.
DELL 1135N WILL NOT SCAN MULTIPLE PAGES TO ONE FILE
When you are at the option to "scan to" and you change it to PDF, change the file name and it saves it as that one file. If you don't change the file name it does multiple sheets.
Top Dell Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
Norman Weimar
Norman Weimar
Ngoro
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
