I just need to know how to backflow this pool pump/filter
**DO NOT** attempt to backwash/backflow a cartridge filter. You will destroy it if you do. Instead, you need to remove it from the canister and wash it per the manufacturer's directions.
Here's a video too:
https://www.youtube.com/watch?v=1N1e0CFDcNo
SOURCE: Problems with Intex Krystal Clear Model 635 Pool Filter Pump 1500
No, the pump should not be noisy. It sounds like you have picked up a foreign object in the pump housing. you may have to pull the face off to determine. OR the pump/motor is indeed defective and should be returned.
SOURCE: Need help installing filter pump model 635 for my swimming pool
Just go to the Intex Corp link below. Choose the appropriate pool and/or pump. At the bottom of the page you will see a link for instructional manuals and videos. Hope that helps.
http://www.intexstore.com/ProductList.aspx?categoryID=30
Oh yeah, by the way...you may want to start looking around for another pump for that pool if you plan on using it more than a year. I have had mine for 3 years and I spend more time in the pool vacumming than I do in the house!! The 635 pump is not strong enough for the 18x52 pool nor does it filter out fine silt and sand...it sucks it up and spits it right back into the pool thru the return. Good luck to you
SOURCE: Need to get a manual/directions for Intex pool
HI,
Please click on the below link to buy the manual for your model.There is no free manual available for your model on the net so you will have to buy it for $5.
http://www.coolinflatables.com/product/626825-11
SOURCE: I need a user manual
Are there a number on the side that u can call? Thats how i got my manual for a sta rite pool sand filter and pump. I couldnt find it anywhere online but once i called them they gave me the link that took me right to it. So maybe if u call the 1-800 number located on the filter pump they may be able to help u.....Good Luck!
Maybe this link is your pump check it out
http://www.bestway-uk.com/downloads/Manual_FilterPump_58117_58118.pdf
SOURCE: Someone else asked about getting a new impeller
Is there a pool supply place in your town? That would be a good place to inquire. You may wish to consider a FixYa.com advertiser if you would prefer.
line partly plugged or too small.
5)Plugged basket in skimmer or hair in lint strainer.
6)Dirty filter.
